    Mirror fails to load after git pull
    2 Posts 2 Posters 476 Views 2 Watching
    • T Offline
      theaddies
      I just updated my mirror today. It now fails to load. The log file output is below. I would appreciate any help.
      /home/pi/.pm2/logs/MagicMirror-error.log last 15 lines:
      0|MagicMir |     at f._load (node:electron/js2c/asar_bundle:2:13330)
      0|MagicMir |     at Module.require (node:internal/modules/cjs/loader:1035:19)
      0|MagicMir |     at require (node:internal/modules/cjs/helpers:102:18)
      0|MagicMir |     at Object.<anonymous> (/home/pi/MagicMirror/modules/default/updatenotification/update_helper.js:3:23)
      0|MagicMir |     at Module._compile (node:internal/modules/cjs/loader:1141:14)
      0|MagicMir |     at Module._extensions..js (node:internal/modules/cjs/loader:1196:10)
      0|MagicMir |     at Module.load (node:internal/modules/cjs/loader:1011:32)
      0|MagicMir |     at Module._load (node:internal/modules/cjs/loader:846:12)
      0|MagicMir |     at Object.<anonymous> (/home/pi/MagicMirror/modules/default/updatenotification/node_helper.js:4:22)
      0|MagicMir | (Use `electron --trace-warnings ...` to show where the warning was created)
      0|MagicMir | [07.01.2024 11:17.10.783] [ERROR] (node:1085) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
      0|MagicMir | [1240:0107/111712.522791:ERROR:gpu_memory_buffer_support_x11.cc(44)] dri3 extension not supported.
        sdetweil @theaddies
        @theaddies you also must do
        npm run install-mm
        and you need to upgrade node to v 18 or 20 it below that…
        recommend my upgrade script, instead of doing it manually
        use force instead of apply
        as you have already dragged down the new code
