    suddenly the screen can't turn on
    15 Posts 4 Posters 5.2k Views 4 Watching
    • L Offline
      lkthomas @sdetweil
      @sdetweil nope, I was using a 3 years old OS, so I did an upgrade to latest version of the OS on my RPi 3B+, problem still the same.
        sdetweil @lkthomas
        @lkthomas do it failed before you upgraded the os.
        • L Offline
          lkthomas @sdetweil
          @sdetweil yes, it failed even before upgrading the OS, it’s not “upgrading”, it’s a fresh install
            MyMirror @lkthomas
            @lkthomas
            Give this a try:
            in /boot/config.txt
            change
            dtoverlay=vc4-kms-v3d
            to
            dtoverlay=vc4-fkms-v3d
            then
            vcgencmd display_power 1
            vcgencmd display_power 0
            BR
            Jens
            L 2 Replies Last reply Reply Quote 0
            • L Offline
              lkthomas @MyMirror
              @MyMirror testing now, but isn’t fkms deprecated already?
              • L Offline
                lkthomas @MyMirror
                @MyMirror I got the same issue using FKMS with “vcgencmd display_power 1” command, it got blank screen after 2 seconds of showing the object on the monitor
                  MyMirror @lkthomas
                  @lkthomas
                  Hmm, you are on Bookworm, right?
                  Maybe this helps: https://forums.raspberrypi.com/viewtopic.php?t=358689
                    schris88
                    I was just trying to get a PIR Sensor running to toggle the display on Pi5 and this was the way to go on a fresh OS install, maybe it´ll help you out too
                    WAYLAND_DISPLAY=“wayland-1” wlr-randr --output HDMI-A-1 --off
                    WAYLAND_DISPLAY=“wayland-1” wlr-randr --output HDMI-A-1 --on
                    If you monitor turns back on by itself after ~10 secs add vc4.force_hotplug=1 (1=hmdi1 / 2=hdmi2 / 3=both) to the end of your /boot/firmware/cmdline.txt
                    if you´re running rotated you can add that as --transform 90 (more options see wlr-randr --help)
                    vcgencmd, xrandr and xset were not working anymore for me
                      sdetweil @schris88
                      @schris88 only pi4 or 5 will have Wayland display manager.
                      pi3 is still on x11
                      • L Offline
                        lkthomas @sdetweil
                        @sdetweil I am using RPi 3B+
