    suddenly the screen can't turn on
    15 Posts 4 Posters 6.7k Views 4 Watching
    • L
      lkthomas @sdetweil
      @sdetweil sorry what do you mean?
        sdetweil @lkthomas
        @lkthomas you made no changes to the system before this trouble?
        L 1 Reply Last reply
        • L
          lkthomas @sdetweil
          @sdetweil nope, I was using a 3 years old OS, so I did an upgrade to latest version of the OS on my RPi 3B+, problem still the same.
            sdetweil @lkthomas
            @lkthomas do it failed before you upgraded the os.
            • L
              lkthomas @sdetweil
              @sdetweil yes, it failed even before upgrading the OS, it’s not “upgrading”, it’s a fresh install
              M 1 Reply Last reply
                MyMirror @lkthomas
                @lkthomas
                Give this a try:
                in /boot/config.txt
                change
                dtoverlay=vc4-kms-v3d
                to
                dtoverlay=vc4-fkms-v3d
                then
                vcgencmd display_power 1
                vcgencmd display_power 0
                BR
                Jens
                L 2 Replies Last reply
                • L
                  lkthomas @MyMirror
                  @MyMirror testing now, but isn’t fkms deprecated already?
                  • L
                    lkthomas @MyMirror
                    @MyMirror I got the same issue using FKMS with “vcgencmd display_power 1” command, it got blank screen after 2 seconds of showing the object on the monitor
                      MyMirror @lkthomas
                      @lkthomas
                      Hmm, you are on Bookworm, right?
                      Maybe this helps: https://forums.raspberrypi.com/viewtopic.php?t=358689
                        schris88
                        I was just trying to get a PIR Sensor running to toggle the display on Pi5 and this was the way to go on a fresh OS install, maybe it´ll help you out too
                        WAYLAND_DISPLAY=“wayland-1” wlr-randr --output HDMI-A-1 --off
                        WAYLAND_DISPLAY=“wayland-1” wlr-randr --output HDMI-A-1 --on
                        If you monitor turns back on by itself after ~10 secs add vc4.force_hotplug=1 (1=hmdi1 / 2=hdmi2 / 3=both) to the end of your /boot/firmware/cmdline.txt
                        if you´re running rotated you can add that as --transform 90 (more options see wlr-randr --help)
                        vcgencmd, xrandr and xset were not working anymore for me
                          sdetweil @schris88
                          @schris88 only pi4 or 5 will have Wayland display manager.
                          pi3 is still on x11
                          • L
                            lkthomas @sdetweil
                            @sdetweil I am using RPi 3B+
                              sdetweil @lkthomas
                              @lkthomas yes @schris88 gave you a solution that you can’t use.
