    suddenly the screen can't turn on
    15 Posts 4 Posters 5.4k Views 4 Watching
    • L Offline
      lkthomas
      I am using the following command to turn off and on the screen at the scheduled time, it has been working fine for years until the last few weeks, the screen will be on using --auto command but its blank, if I quickly do the --off again, wait until the screen go to sleep mode itself and run --auto, the screen will start without issue, since this problem is unpredictable, would it caused by hardware issue? would it be the cable or the screen?
      export DISPLAY=:0 && xrandr --output HDMI-1 --off
      export DISPLAY=:0 && xrandr --output HDMI-1 --auto
        sdetweil @lkthomas
        @lkthomas no other changes?
        • L Offline
          lkthomas @sdetweil
          @sdetweil sorry what do you mean?
            sdetweil @lkthomas
            @lkthomas you made no changes to the system before this trouble?
            • L Offline
              lkthomas @sdetweil
              @sdetweil nope, I was using a 3 years old OS, so I did an upgrade to latest version of the OS on my RPi 3B+, problem still the same.
                sdetweil @lkthomas
                @lkthomas do it failed before you upgraded the os.
                • L Offline
                  lkthomas @sdetweil
                  @sdetweil yes, it failed even before upgrading the OS, it’s not “upgrading”, it’s a fresh install
                    MyMirror @lkthomas
                    @lkthomas
                    Give this a try:
                    in /boot/config.txt
                    change
                    dtoverlay=vc4-kms-v3d
                    to
                    dtoverlay=vc4-fkms-v3d
                    then
                    vcgencmd display_power 1
                    vcgencmd display_power 0
                    BR
                    Jens
                    L 2 Replies Last reply Reply Quote 0
                    • L Offline
                      lkthomas @MyMirror
                      @MyMirror testing now, but isn’t fkms deprecated already?
                      • L Offline
                        lkthomas @MyMirror
                        @MyMirror I got the same issue using FKMS with “vcgencmd display_power 1” command, it got blank screen after 2 seconds of showing the object on the monitor
                          MyMirror @lkthomas
                          @lkthomas
                          Hmm, you are on Bookworm, right?
                          Maybe this helps: https://forums.raspberrypi.com/viewtopic.php?t=358689
                            schris88
                            I was just trying to get a PIR Sensor running to toggle the display on Pi5 and this was the way to go on a fresh OS install, maybe it´ll help you out too
                            WAYLAND_DISPLAY=“wayland-1” wlr-randr --output HDMI-A-1 --off
                            WAYLAND_DISPLAY=“wayland-1” wlr-randr --output HDMI-A-1 --on
                            If you monitor turns back on by itself after ~10 secs add vc4.force_hotplug=1 (1=hmdi1 / 2=hdmi2 / 3=both) to the end of your /boot/firmware/cmdline.txt
                            if you´re running rotated you can add that as --transform 90 (more options see wlr-randr --help)
                            vcgencmd, xrandr and xset were not working anymore for me
                              sdetweil @schris88
                              @schris88 only pi4 or 5 will have Wayland display manager.
                              pi3 is still on x11
                              • L Offline
                                lkthomas @sdetweil
                                @sdetweil I am using RPi 3B+
                                  sdetweil @lkthomas
                                  @lkthomas yes @schris88 gave you a solution that you can’t use.
