    Google Calendars not loading
    28 Posts 7 Posters 16.2k Views 7 Watching
      mspk
      Hi everyone!
      I just started my raspberry pi / MM journey a few days ago and oh boy!
      It has not been easy… Finally, after 40ish hours of programming, i figured out what to do.
      I am using an Raspberry Pi Zero 2W for my MM with Raspberry Pi OS, 32-bit version and an 1080p monitor (if that is important).
      I tried installing MM both manually and with @sdetweil’s script, but for some reason, I can’t get my calendars to run as they should.
      I tried testing every calendar separately too, which all get the same error. Form searching the forum, it seems to be a GPU issue… can somebody please help?
      Warning: vkCreateInstance: Found no drivers!
      0|MagicMirror  | Warning: vkCreateInstance failed with VK_ERROR_INCOMPATIBLE_DRIVER
      0|MagicMirror  |     at CheckVkSuccessImpl (../../third_party/dawn/src/dawn/native/vulkan/VulkanError.cpp:101)
      0|MagicMirror  |     at CreateVkInstance (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:493)
      0|MagicMirror  |     at Initialize (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:379)
      0|MagicMirror  |     at Create (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:301)
      0|MagicMirror  |     at operator() (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:556)
      Cheers!
        sdetweil @mspk
        @mspk those are garbage messages… from a bug in electron… the actual errors are closer to the top
          @mspk weird…
          your post was makred as spam which I can’t override…
          please use a code block around this info
          paste text(blank line above and below)
          select text just pasted
          hit the button </>
          if you used my script, I increased the size of the swap space
          free -m
          should show that
          calendars keep all the OLD events… since the calendar was created… SO… you could have a LOT of entries to process…
          your spam post shows calendars sending events to the front end to display
            mspk @sdetweil
            @sdetweil I’ll try that. Funny aboutz the spam, I used the </> button…
              mspk @sdetweil
              pi@raspberrypi:~ $ free -m
                             total        used        free      shared  buff/cache   available
              Mem:             363         169          88          23         105         115
              Swap:           2047         227        1820
                sdetweil @mspk
                @mspk said in Google Calendars not loading:
                Mem: 363
                weird that there is only 363… as its supposed to have 512…
                I have one here… I’ll power it up
                  @mspk doc
                  The installed RAM is 524,288KB.
                  The usable RAM is 437,868 KB
                  mine
                  Mem:             426         134         117          10         175         232
                  Swap:             99           1          98
                    mspk @sdetweil
                    @sdetweil When I played around a bit, i gave the gpu 128MB, I guess thats why. Just set it back to 64, and now it shows 426 for me too. But the calendars are still not complete…
                    The status right now is following:
                    Calendar 1 seems to be complete.
                    Calandar 2 is not loading at all.
                    Calendar 3 seems complete (i guess for the one month that it shows in my module).
                    Calendar 4 is there, but not updated (I changed the title).
                    Calendar 5 is also missing.
                    Do I need to reset something maybe?
                    P.S.: It’ still slow.
                      sdetweil @mspk
                      @mspk are u willing to share the url of one of the not loading cals…
                      you can use chat here so no email flow…
                        @mspk all of the urls worked without issue
                        so, try this
                        stop mm
                        cd ~/MagicMirror
                        npm install electron@28.1.1
                        retry MM
                          mspk @sdetweil
                          @sdetweil Already did that a few hours ago, but nothing changed…
                            sdetweil @mspk
                            @mspk ok, one other thing, in the system network preferences, disable ipv6
                            desktop, menu top left, preferences, pi config, network.
                            the electron version is supposed to have the fix for this (trying to talk ipv6 to an ipv4 server… oops can’t connect)
                              mspk @sdetweil
                              also already done.
                                sdetweil @mspk
                                @mspk and rebooted???
                                from command line
                                ip addr
                                  mspk @sdetweil
                                  2: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
                                      link/ether d8:3a:dd:87:e0:80 brd ff:ff:ff:ff:ff:ff
                                      inet 192.168.178.68/24 brd 192.168.178.255 scope global dynamic noprefixroute wlan0
                                         valid_lft 863889sec preferred_lft 755889sec
                                      inet6 2a0b:9e00:116f:fe30:da3a:ddff:fe87:e080/64 scope global dynamic mngtmpaddr
                                         valid_lft 7085sec preferred_lft 3485sec
                                      inet6 fe80::da3a:ddff:fe87:e080/64 scope link
                                         valid_lft forever preferred_lft forever
                                    sdetweil @mspk
                                    still enabled
                                      mspk @sdetweil
                                      @sdetweil disabled it inside the sysctl.conf, dont know why it didn’t change
                                        mspk @mspk
                                        valid_lft 863983sec preferred_lft 755983sec
                                        • V Offline
                                          valentindey
                                          Is there any update on this?
                                          I seem to have the same (or similar) issue on a Raspberry Pi 3. For me it’s just one out of a few calendars that isn’t working and I also get the vulkan error message.
                                          The calendar has been working before but I can’t seem to trace it back to a recent change.
                                          I already started MM with node option --dns-result-order=ipv4first as the calendars come from a Nextcloud instance which does not support ipv6.
                                            sdetweil @valentindey
                                            @valentindey we haven’t got a clear indication where the trouble is. is it in electron, ? or …
                                            did you try electron 28.1.1?
