    Google Calendars not loading
    28 Posts 7 Posters 14.6k Views 7 Watching
      mspk
      Hi everyone!
      I just started my raspberry pi / MM journey a few days ago and oh boy!
      It has not been easy… Finally, after 40ish hours of programming, i figured out what to do.
      I am using an Raspberry Pi Zero 2W for my MM with Raspberry Pi OS, 32-bit version and an 1080p monitor (if that is important).
      I tried installing MM both manually and with @sdetweil’s script, but for some reason, I can’t get my calendars to run as they should.
      I tried testing every calendar separately too, which all get the same error. Form searching the forum, it seems to be a GPU issue… can somebody please help?
      Warning: vkCreateInstance: Found no drivers!
      0|MagicMirror  | Warning: vkCreateInstance failed with VK_ERROR_INCOMPATIBLE_DRIVER
      0|MagicMirror  |     at CheckVkSuccessImpl (../../third_party/dawn/src/dawn/native/vulkan/VulkanError.cpp:101)
      0|MagicMirror  |     at CreateVkInstance (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:493)
      0|MagicMirror  |     at Initialize (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:379)
      0|MagicMirror  |     at Create (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:301)
      0|MagicMirror  |     at operator() (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:556)
      Cheers!
        sdetweil @mspk
        @mspk those are garbage messages… from a bug in electron… the actual errors are closer to the top
          @mspk weird…
          your post was makred as spam which I can’t override…
          please use a code block around this info
          paste text(blank line above and below)
          select text just pasted
          hit the button </>
          if you used my script, I increased the size of the swap space
          free -m
          should show that
          calendars keep all the OLD events… since the calendar was created… SO… you could have a LOT of entries to process…
          your spam post shows calendars sending events to the front end to display
            mspk @sdetweil
            @sdetweil I’ll try that. Funny aboutz the spam, I used the </> button…
              mspk @sdetweil
              pi@raspberrypi:~ $ free -m
                             total        used        free      shared  buff/cache   available
              Mem:             363         169          88          23         105         115
              Swap:           2047         227        1820
                sdetweil @mspk
                @mspk said in Google Calendars not loading:
                Mem: 363
                weird that there is only 363… as its supposed to have 512…
                I have one here… I’ll power it up
                  @mspk doc
                  The installed RAM is 524,288KB.
                  The usable RAM is 437,868 KB
                  mine
                  Mem:             426         134         117          10         175         232
                  Swap:             99           1          98
                    mspk @sdetweil
                    @sdetweil When I played around a bit, i gave the gpu 128MB, I guess thats why. Just set it back to 64, and now it shows 426 for me too. But the calendars are still not complete…
                    The status right now is following:
                    Calendar 1 seems to be complete.
                    Calandar 2 is not loading at all.
                    Calendar 3 seems complete (i guess for the one month that it shows in my module).
                    Calendar 4 is there, but not updated (I changed the title).
                    Calendar 5 is also missing.
                    Do I need to reset something maybe?
                    P.S.: It’ still slow.
                      sdetweil @mspk
                      @mspk are u willing to share the url of one of the not loading cals…
                      you can use chat here so no email flow…
                        @mspk all of the urls worked without issue
                        so, try this
                        stop mm
                        npm install electron@28.1.1
                        retry MM
