    Google Calendars not loading
    28 Posts 7 Posters 17.3k Views 7 Watching
      mspk @sdetweil
      @sdetweil I’ll try that. Funny aboutz the spam, I used the </> button…
        mspk @sdetweil
        pi@raspberrypi:~ $ free -m
                       total        used        free      shared  buff/cache   available
        Mem:             363         169          88          23         105         115
        Swap:           2047         227        1820
          sdetweil @mspk
          @mspk said in Google Calendars not loading:
          Mem: 363
          weird that there is only 363… as its supposed to have 512…
          I have one here… I’ll power it up
            @mspk doc
            The installed RAM is 524,288KB.
            The usable RAM is 437,868 KB
            mine
            Mem:             426         134         117          10         175         232
            Swap:             99           1          98
            M 1 Reply Last reply
              mspk @sdetweil
              @sdetweil When I played around a bit, i gave the gpu 128MB, I guess thats why. Just set it back to 64, and now it shows 426 for me too. But the calendars are still not complete…
              The status right now is following:
              Calendar 1 seems to be complete.
              Calandar 2 is not loading at all.
              Calendar 3 seems complete (i guess for the one month that it shows in my module).
              Calendar 4 is there, but not updated (I changed the title).
              Calendar 5 is also missing.
              Do I need to reset something maybe?
              P.S.: It’ still slow.
                sdetweil @mspk
                @mspk are u willing to share the url of one of the not loading cals…
                you can use chat here so no email flow…
                S M 2 Replies Last reply
                  @mspk all of the urls worked without issue
                  so, try this
                  stop mm
                  npm install electron@28.1.1
                  retry MM
                    mspk @sdetweil
                    @sdetweil Already did that a few hours ago, but nothing changed…
                      sdetweil @mspk
                      @mspk ok, one other thing, in the system network preferences, disable ipv6
                      desktop, menu top left, preferences, pi config, network.
                      the electron version is supposed to have the fix for this (trying to talk ipv6 to an ipv4 server… oops can’t connect)
                        mspk @sdetweil
                        also already done.
                          sdetweil @mspk
                          @mspk and rebooted???
                          from command line
                          ip addr
                            mspk @sdetweil
                            2: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
                                link/ether d8:3a:dd:87:e0:80 brd ff:ff:ff:ff:ff:ff
                                inet 192.168.178.68/24 brd 192.168.178.255 scope global dynamic noprefixroute wlan0
                                   valid_lft 863889sec preferred_lft 755889sec
                                inet6 2a0b:9e00:116f:fe30:da3a:ddff:fe87:e080/64 scope global dynamic mngtmpaddr
                                   valid_lft 7085sec preferred_lft 3485sec
                                inet6 fe80::da3a:ddff:fe87:e080/64 scope link
                                   valid_lft forever preferred_lft forever
                              sdetweil @mspk
                              still enabled
                                mspk @sdetweil
                                @sdetweil disabled it inside the sysctl.conf, dont know why it didn’t change
                                  mspk @mspk
                                  valid_lft 863983sec preferred_lft 755983sec
                                  • V
                                    valentindey
                                    Is there any update on this?
                                    I seem to have the same (or similar) issue on a Raspberry Pi 3. For me it’s just one out of a few calendars that isn’t working and I also get the vulkan error message.
                                    The calendar has been working before but I can’t seem to trace it back to a recent change.
                                    I already started MM with node option --dns-result-order=ipv4first as the calendars come from a Nextcloud instance which does not support ipv6.
                                      sdetweil @valentindey
                                      @valentindey we haven’t got a clear indication where the trouble is. is it in electron, ? or …
                                      did you try electron 28.1.1?
                                      V 1 Reply Last reply
                                      • V
                                        valentindey @sdetweil
                                        @sdetweil yes, I tried an older version and the newer version of electron. So far to no avail.
                                        Checking the logs I see that events are fetched from the calendar in question, so it’s something about displaying them.
                                        Also, running the exact same setup on another machine works perfectly fine.
                                          @valentindey yeh, its weird for sure…
                                          lets go back to the prior parser
                                          npm install node-ical@0.16.1
                                          and restart MagcMirror
                                          eniacE V 2 Replies Last reply
                                          • eniacE
                                            eniac @sdetweil
                                            @sdetweil said in Google Calendars not loading:
                                            let`s go back to the prior parser
                                            Does the Job. Thank you …
