    Google Calendars not loading
    28 Posts 7 Posters 16.9k Views 7 Watching
      @mspk doc
      The installed RAM is 524,288KB.
      The usable RAM is 437,868 KB
      mine
                    total        used        free      shared  buff/cache   available
      Mem:             426         134         117          10         175         232
      Swap:             99           1          98
        mspk @sdetweil
        @sdetweil When I played around a bit, i gave the gpu 128MB, I guess thats why. Just set it back to 64, and now it shows 426 for me too. But the calendars are still not complete…
        The status right now is following:
        Calendar 1 seems to be complete.
        Calandar 2 is not loading at all.
        Calendar 3 seems complete (i guess for the one month that it shows in my module).
        Calendar 4 is there, but not updated (I changed the title).
        Calendar 5 is also missing.
        Do I need to reset something maybe?
        P.S.: It’ still slow.
          sdetweil @mspk
          @mspk are u willing to share the url of one of the not loading cals…
          you can use chat here so no email flow…
            @mspk all of the urls worked without issue
            so, try this
            stop mm
            npm install electron@28.1.1
            retry MM
              mspk @sdetweil
              @sdetweil Already did that a few hours ago, but nothing changed…
                sdetweil @mspk
                @mspk ok, one other thing, in the system network preferences, disable ipv6
                desktop, menu top left, preferences, pi config, network.
                the electron version is supposed to have the fix for this (trying to talk ipv6 to an ipv4 server… oops can’t connect)
                  mspk @sdetweil
                  also already done.
                    sdetweil @mspk
                    @mspk and rebooted???
                    from command line
                    ip addr
                      mspk @sdetweil
                      2: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
                          link/ether d8:3a:dd:87:e0:80 brd ff:ff:ff:ff:ff:ff
                          inet 192.168.178.68/24 brd 192.168.178.255 scope global dynamic noprefixroute wlan0
                             valid_lft 863889sec preferred_lft 755889sec
                          inet6 2a0b:9e00:116f:fe30:da3a:ddff:fe87:e080/64 scope global dynamic mngtmpaddr
                             valid_lft 7085sec preferred_lft 3485sec
                          inet6 fe80::da3a:ddff:fe87:e080/64 scope link
                             valid_lft forever preferred_lft forever
                        sdetweil @mspk
                        @mspk said in Google Calendars not loading:
                        still enabled
                          mspk @sdetweil
                          @sdetweil disabled it inside the sysctl.conf, dont know why it didn’t change
                            mspk @mspk
                            valid_lft 863983sec preferred_lft 755983sec
                            • V Offline
                              valentindey
                              Is there any update on this?
                              I seem to have the same (or similar) issue on a Raspberry Pi 3. For me it’s just one out of a few calendars that isn’t working and I also get the vulkan error message.
                              The calendar has been working before but I can’t seem to trace it back to a recent change.
                              I already started MM with node option --dns-result-order=ipv4first as the calendars come from a Nextcloud instance which does not support ipv6.
                                sdetweil @valentindey
                                @valentindey we haven’t got a clear indication where the trouble is. is it in electron, ? or …
                                did you try electron 28.1.1?
                                • V Offline
                                  valentindey @sdetweil
                                  @sdetweil yes, I tried an older version and the newer version of electron. So far to no avail.
                                  Checking the logs I see that events are fetched from the calendar in question, so it’s something about displaying them.
                                  Also, running the exact same setup on another machine works perfectly fine.
                                    @valentindey yeh, its weird for sure…
                                    lets go back to the prior parser
                                    npm install node-ical@0.16.1
                                    and restart MagcMirror
                                    eniacE V 2 Replies Last reply Reply Quote 0
                                    • eniacE Offline
                                      eniac @sdetweil
                                      @sdetweil said in Google Calendars not loading:
                                      let`s go back to the prior parser
                                      Does the Job. Thank you …
                                        sdetweil @eniac
                                        @eniac thanks for the feedback
                                          shizzlesticks
                                          I updated my MagicMirror this week and have been struggling to figure out why my Google calendars weren’t loading. It was the parser for sure… Thank you!
                                          • V Offline
                                            @sdetweil this works for me as well. Thanks a lot for the help, very much appreciated!
