    Everything was going so well
    52 Posts 4 Posters 20.1k Views 3 Watching
      sdetweil @JMac
      @JMac yes sda has two partitions boot and rootfs
      but you need to run e2fsck on /dev/sda2
      e2fsck mean extended version 2, file system check
        JMac
        so should i also run sudo umount /dev/sda2 before running sudo e2fsck -f -v /dev/sda2?
          sdetweil @JMac
          @JMac yes
            JMac @sdetweil
            @sdetweil so I’ve run sudo umount /dev/sda1 and the same for sda2 and both folders have disappeared off the home screen.
            which e2fsck do I run if i had to unmount 2 drives?
              sdetweil @JMac
              @JMac unmount means remove them from normal file system access
              the device names still exist
              as e2fsck could modify the file system blocks on the drive, you don’t want to do that while you could still copy a file there
              so you are passing the hardware name to e2fsck
                JMac @sdetweil
                @sdetweil so do I run e2fsck -f -v /dev/sda1 or e2fsck -f -v /dev/sda2
                or does it not matter?
                I’m struggling here to the bigger picture so can’t see the logic of the steps.
                  sdetweil @JMac
                  @JMac ok bigger picture, in Linux
                  hardware devices are named. see the output of ls /dev
                  disk devices are usually named sd??? where xxx is a letter, and partition number
                  letter a is the first device b the second etc
                  sometime in the past the type of storage device was also used as part of the name, scsi, atapi …
                  for this case they are named sd (storage device)
                  sda is the first storage device
                  sda1 is the first partition on the sda device
                  on those partitions are a logical way of storing data. most linux and all windows devices store file data in sectors, 512 byte chunks called sectors. and then the file system (way of organizing those sectors)
                  applies some data structure on top. it’s a directory or a file. tables in other sectors build trees of data to describe the entire partition.
                  there are different layouts depending on vendor and intended use
                  FAT, exFAT, NTFS EXT3, EXT4, and a host of others.
                  all is wonderful until some sector or more gets damaged… machine was powered off during write, a hardware failure…
                  now the filesystem code is confused… says read sector 853, and the bits there will tell it where the next sector is for this file. but the bits don’t point to the right place… Oops
                  some file systems include a duplicate set of bits do there is an alternative way . some use them only for recovery.
                  sd card hardware is known for being fragile. it was designed for lots of reads,with few writes. camera picture music file. NOT an os that is waiting logs and other stuff constantly.
                  anyhow.
                  to check and correct these kinds of problems with the Linux ext file system we need to run thr fsck program on the raw partition. and make sure that moone else is using it.
                  unmount takes it out of circulation. no users files open
                  fsck and e2fsck need to read the raw sectors on the partition, but we just unmounted it.
                  so we need to provide the hardware name for the program to use.
                    JMac @sdetweil
                    @sdetweil Wow, that was a bit to take in but makes sense (I think).
                    So if I unmount it how do I get the information off it?
                    what are the steps here?
                      sdetweil @JMac
                      @JMac
                      unmount it
                      run fsck against it
                      remount it (hopefully fixed)
                      then copy your data first thing, DO NOT WRITE TO THE SD CARD
                      config.js
                      custom.css
                      and a list of all the modules in modules (ls *)
                      if u WANT to try in each module folder do
                      git remote -v
                      ```⁷
                      so we know where it came from
                      quickest way in each module folder
                      git remote -v | tail -a ~/module_list
                      this will list to github source (git remote -v) and append that info  (tail -a) to a known file in your home folder (~ = home)
                      this is what my backup script does
                      IF you have any modules that require authentication (run an auth script)
                      ls *.json while you are there,
                      you could also run my backup script, from the web page copy/paste  with -s  pointing to the mounted folder MagicMirror
                      ...MM_backup -s /media/??????/MagicMirror some gobbleygoop name (tab key will fill it in after the 1st letter)
                      this will create the MM_backup folder in your logged on user home folder..
                      and do all the work described above (after the mount)
                        JMac
                        had a little crack at this again, the Mrs is bugging me to get “her” mirror back up and running.
                        So I’ve run sudo umount /dev/sda1
                        Both drive folders from the mounted (old) SD disappeared from the home screen on the pi as expected.
                        then run, (and got)
                        e2fsck 1.46.2 (28-feb-2021)
                        rootfs: recovering journal
                        superblock needs_recovery flag is clear but journal has data.
                        Run journal anyway ? YES
                        e2fsck: unable to set superblock flags on rootfs
                        rootfs: *********** WARNING: filesytem still has errors *********
                        • 6
                        • 4 / 6
