    Everything was going so well
    52 Posts 4 Posters 23.5k Views 3 Watching
      sdetweil @JMac
      @JMac bummer
      from search
      https://unix.stackexchange.com/questions/327863/fsck-wont-fsck-unable-to-set-superblock-flags/386886#386886
      was the card readable at all? if so
      take it out and put it back in to get mounted
      and copy the old config.js, custom.css and do
      ls >~/savedlist.txt
      in the MagicMirror/modules folder
      to some file on your booted card
      then we can help you rebuild a new sd card
      J 2 Replies Last reply Reply Quote 0
        JMac @sdetweil
        @sdetweil hey Sam, I can still see the old list of modules on the old SD card.
        If that’s the case can the old card still be used?
        the new card is just a completely empty Pi OS, nothing to do with MM on there yet.
        Do I need in run the basic install for MM on the new SD to get that running?
          sdetweil @JMac
          @JMac yes, you need to install MM on the new sd.
          use my script…
          see https://github.com/sdetweil/MagicMirror_scripts
          but you should extract your MM config from the sd card.
          use my backup script to point to the mounted sd card
          see https://github.com/sdetweil/MagicMirror-backup-restore
          then install MM
          and then restore the config saved to the new sdcard (~/MM_backup folder)
            JMac @sdetweil
            @sdetweil So install the base of MM on the new SD then follow the steps in your previous post?
            I have a feeling it definitely won’t be that easy.
              sdetweil @JMac
              @JMac back is copy/paste from the github, add -s/media/{user}/mountname/MagicMirror
              then install MagicMirror
              copy/paste from the github link
              then restore, copy/paste from the github link. no parms required
                JMac @sdetweil
                @sdetweil right so when I copy those 2 file’s am I literally just dragging a copy to the new SD’s home screen (just so they’re on the new card) or do they need to go into a MM specific folder on the new card.
                I can find both of those files on the old SD but I’m not understanding from
                ls >~savedlist.txt.
                am I doing that after I’ve installed a fresh MM on the new SD card once that MagicMirror/modules folder exists because running the above command won’t work as the new SD has no reference to MM’s existence.
                  sdetweil @JMac
                  @JMac copy ?
                  you go to the web page, and click copy for the command
                  then to terminal window or ssh window, paste command, hit enter (install and restore, add -s parm on backup)
                  you are executing the command directly from the web
                    JMac @sdetweil
                    @sdetweil so I’m not manually moving the config and CSS files myself that will be done after via terminal?
                      sdetweil @JMac
                      @JMac correct the backup/restore will do all that, and get the module list and restore them
                        JMac @sdetweil
                        @sdetweil new install of MM is one the new SD (failed the first time so had to run again and seemed to take a while).
                        when I run your backup script will it automatically find the previous MM install on the old SD card mounted with USB?
                        if not how do I get it to find the previous install to copy the files I need?
                          sdetweil @JMac
                          @JMac no it will not find automatically
                          u meed to find it ls /media/your_username
                          username is pi?
                            @sdetweil did you get back running?
                            • 3 / 3
