    Everything was going so well
    52 Posts 4 Posters 21.6k Views 3 Watching
      JMac @sdetweil
      @sdetweil right so when I copy those 2 file’s am I literally just dragging a copy to the new SD’s home screen (just so they’re on the new card) or do they need to go into a MM specific folder on the new card.
      I can find both of those files on the old SD but I’m not understanding from
      ls >~savedlist.txt.
      am I doing that after I’ve installed a fresh MM on the new SD card once that MagicMirror/modules folder exists because running the above command won’t work as the new SD has no reference to MM’s existence.
        sdetweil @JMac
        @JMac copy ?
        you go to the web page, and click copy for the command
        then to terminal window or ssh window, paste command, hit enter (install and restore, add -s parm on backup)
        you are executing the command directly from the web
          JMac @sdetweil
          @sdetweil so I’m not manually moving the config and CSS files myself that will be done after via terminal?
            sdetweil @JMac
            @JMac correct the backup/restore will do all that, and get the module list and restore them
              JMac @sdetweil
              @sdetweil new install of MM is one the new SD (failed the first time so had to run again and seemed to take a while).
              when I run your backup script will it automatically find the previous MM install on the old SD card mounted with USB?
              if not how do I get it to find the previous install to copy the files I need?
                sdetweil @JMac
                @JMac no it will not find automatically
                u meed to find it ls /media/your_username
                username is pi?
                  @sdetweil did you get back running?
                  • 5 / 6
