    Everything was going so well
    52 Posts 4 Posters 26.9k Views 3 Watching
      JMac @sdetweil
      @sdetweil hey Sam, I can still see the old list of modules on the old SD card.
      If that’s the case can the old card still be used?
      the new card is just a completely empty Pi OS, nothing to do with MM on there yet.
      Do I need in run the basic install for MM on the new SD to get that running?
        sdetweil @JMac
        @JMac yes, you need to install MM on the new sd.
        use my script…
        see https://github.com/sdetweil/MagicMirror_scripts
        but you should extract your MM config from the sd card.
        use my backup script to point to the mounted sd card
        see https://github.com/sdetweil/MagicMirror-backup-restore
        then install MM
        and then restore the config saved to the new sdcard (~/MM_backup folder)
        J 1 Reply Last reply
          JMac @sdetweil
          @sdetweil So install the base of MM on the new SD then follow the steps in your previous post?
          I have a feeling it definitely won’t be that easy.
            sdetweil @JMac
            @JMac back is copy/paste from the github, add -s/media/{user}/mountname/MagicMirror
            then install MagicMirror
            copy/paste from the github link
            then restore, copy/paste from the github link. no parms required
              JMac @sdetweil
              @sdetweil right so when I copy those 2 file’s am I literally just dragging a copy to the new SD’s home screen (just so they’re on the new card) or do they need to go into a MM specific folder on the new card.
              I can find both of those files on the old SD but I’m not understanding from
              ls >~savedlist.txt.
              am I doing that after I’ve installed a fresh MM on the new SD card once that MagicMirror/modules folder exists because running the above command won’t work as the new SD has no reference to MM’s existence.
                sdetweil @JMac
                @JMac copy ?
                you go to the web page, and click copy for the command
                then to terminal window or ssh window, paste command, hit enter (install and restore, add -s parm on backup)
                you are executing the command directly from the web
                  JMac @sdetweil
                  @sdetweil so I’m not manually moving the config and CSS files myself that will be done after via terminal?
                    sdetweil @JMac
                    @JMac correct the backup/restore will do all that, and get the module list and restore them
                      JMac @sdetweil
                      @sdetweil new install of MM is one the new SD (failed the first time so had to run again and seemed to take a while).
                      when I run your backup script will it automatically find the previous MM install on the old SD card mounted with USB?
                      if not how do I get it to find the previous install to copy the files I need?
                        sdetweil @JMac
                        @JMac no it will not find automatically
                        u meed to find it ls /media/your_username
                        username is pi?
                          @sdetweil did you get back running?
                          • 3 / 3
