    Everything was going so well
    52 Posts 4 Posters 23.8k Views 3 Watching
      sdetweil @JMac
      @JMac yes, you must use sudo on both commands unmount and fsck
      sorry I was unclear
      normal users should not be able to mess with hardware, so one must act as root
        JMac @sdetweil
        @sdetweil I run sudo umount…
        and get
        umount:… not mounted,
        then run
        sudo e2fsck -f -v /dev/sda
        and get
        e2fsck 1.46.2 (28-feb-2021)
        /dev/sda is in use
        efsck: connot continue, aborting.
          sdetweil @JMac
          @JMac hm… wonder what is using it?
          can you open the disks app on the pi from the dedktop menu
            JMac @sdetweil
            @sdetweil on the home screen I have 2 drive icons under the wastebasket.
            one is boot
            the other is rootfs
            i then have the option to eject these in the file manager
              sdetweil @JMac
              @JMac there should be that drive on /dev/sda too
                JMac @sdetweil
                @sdetweil I’m a little confused (I’d imagine thats pretty clear at this point).
                i run sudo fdisk -1
                and get
                Disk /dev/ram0 through to Disk /dev/ram15
                the list then has
                Disk/dev/mmcblk0: 7.4GiB (my thinking is this is the current/new sd card)
                Device
                /dev/mmcblk0p1
                /dev/mmcblk0p2
                Disk /dev/sda:59.69 GiB (I again assume this is the old SD with my original MM setup)
                Device
                /dev/sda1
                /dev/sda/2
                end of the list.
                does any of that make sense/ is any of it what I’m looking for? I’ve obviously taken out several lines under each of those headers just for space and time typing.
                  sdetweil @JMac
                  @JMac yes sda has two partitions boot and rootfs
                  but you need to run e2fsck on /dev/sda2
                  e2fsck mean extended version 2, file system check
                    JMac
                    so should i also run sudo umount /dev/sda2 before running sudo e2fsck -f -v /dev/sda2?
                      sdetweil @JMac
                      @JMac yes
                        JMac @sdetweil
                        @sdetweil so I’ve run sudo umount /dev/sda1 and the same for sda2 and both folders have disappeared off the home screen.
                        which e2fsck do I run if i had to unmount 2 drives?
                          sdetweil @JMac
                          @JMac unmount means remove them from normal file system access
                          the device names still exist
                          as e2fsck could modify the file system blocks on the drive, you don’t want to do that while you could still copy a file there
                          so you are passing the hardware name to e2fsck
                            JMac @sdetweil
                            @sdetweil so do I run e2fsck -f -v /dev/sda1 or e2fsck -f -v /dev/sda2
                            or does it not matter?
                            I’m struggling here to the bigger picture so can’t see the logic of the steps.
                              sdetweil @JMac
                              @JMac ok bigger picture, in Linux
                              hardware devices are named. see the output of ls /dev
                              disk devices are usually named sd??? where xxx is a letter, and partition number
                              letter a is the first device b the second etc
                              sometime in the past the type of storage device was also used as part of the name, scsi, atapi …
                              for this case they are named sd (storage device)
                              sda is the first storage device
                              sda1 is the first partition on the sda device
                              on those partitions are a logical way of storing data. most linux and all windows devices store file data in sectors, 512 byte chunks called sectors. and then the file system (way of organizing those sectors)
                              applies some data structure on top. it’s a directory or a file. tables in other sectors build trees of data to describe the entire partition.
                              there are different layouts depending on vendor and intended use
                              FAT, exFAT, NTFS EXT3, EXT4, and a host of others.
                              all is wonderful until some sector or more gets damaged… machine was powered off during write, a hardware failure…
                              now the filesystem code is confused… says read sector 853, and the bits there will tell it where the next sector is for this file. but the bits don’t point to the right place… Oops
                              some file systems include a duplicate set of bits do there is an alternative way . some use them only for recovery.
                              sd card hardware is known for being fragile. it was designed for lots of reads,with few writes. camera picture music file. NOT an os that is waiting logs and other stuff constantly.
                              anyhow.
                              to check and correct these kinds of problems with the Linux ext file system we need to run thr fsck program on the raw partition. and make sure that moone else is using it.
                              unmount takes it out of circulation. no users files open
                              fsck and e2fsck need to read the raw sectors on the partition, but we just unmounted it.
                              so we need to provide the hardware name for the program to use.
                                JMac @sdetweil
                                @sdetweil Wow, that was a bit to take in but makes sense (I think).
                                So if I unmount it how do I get the information off it?
                                what are the steps here?
                                  sdetweil @JMac
                                  @JMac
                                  unmount it
                                  run fsck against it
                                  remount it (hopefully fixed)
                                  then copy your data first thing, DO NOT WRITE TO THE SD CARD
                                  config.js
                                  custom.css
                                  and a list of all the modules in modules (ls *)
                                  if u WANT to try in each module folder do
                                  git remote -v
                                  ```⁷
                                  so we know where it came from
                                  quickest way in each module folder
                                  git remote -v | tail -a ~/module_list
                                  this will list to github source (git remote -v) and append that info  (tail -a) to a known file in your home folder (~ = home)
                                  this is what my backup script does
                                  IF you have any modules that require authentication (run an auth script)
                                  ls *.json while you are there,
                                  you could also run my backup script, from the web page copy/paste  with -s  pointing to the mounted folder MagicMirror
                                  https://github.com/sdetweil/MagicMirror-backup-restore
                                  ...MM_backup -s /media/??????/MagicMirror some gobbleygoop name (tab key will fill it in after the 1st letter)
                                  this will create the MM_backup folder in your logged on user home folder..
                                  and do all the work described above (after the mount)
                                    JMac
                                    had a little crack at this again, the Mrs is bugging me to get “her” mirror back up and running.
                                    So I’ve run sudo umount /dev/sda1
                                    Both drive folders from the mounted (old) SD disappeared from the home screen on the pi as expected.
                                    then run, (and got)
                                    rootfs: recovering journal
                                    superblock needs_recovery flag is clear but journal has data.
                                    Run journal anyway ? YES
                                    e2fsck: unable to set superblock flags on rootfs
                                    rootfs: *********** WARNING: filesytem still has errors *********
                                      sdetweil @JMac
                                      @JMac bummer
                                      from search
                                      https://unix.stackexchange.com/questions/327863/fsck-wont-fsck-unable-to-set-superblock-flags/386886#386886
                                      was the card readable at all? if so
                                      take it out and put it back in to get mounted
                                      and copy the old config.js, custom.css and do
                                      ls >~/savedlist.txt
                                      in the MagicMirror/modules folder
                                      to some file on your booted card
                                      then we can help you rebuild a new sd card
                                        JMac @sdetweil
                                        @sdetweil hey Sam, I can still see the old list of modules on the old SD card.
                                        If that’s the case can the old card still be used?
                                        the new card is just a completely empty Pi OS, nothing to do with MM on there yet.
                                        Do I need in run the basic install for MM on the new SD to get that running?
                                          sdetweil @JMac
                                          @JMac yes, you need to install MM on the new sd.
                                          use my script…
                                          see https://github.com/sdetweil/MagicMirror_scripts
                                          but you should extract your MM config from the sd card.
                                          use my backup script to point to the mounted sd card
                                          see https://github.com/sdetweil/MagicMirror-backup-restore
                                          then install MM
                                          and then restore the config saved to the new sdcard (~/MM_backup folder)
                                            JMac @sdetweil
                                            @sdetweil So install the base of MM on the new SD then follow the steps in your previous post?
                                            I have a feeling it definitely won’t be that easy.
                                            • 2 / 3
