    Everything was going so well
    52 Posts 4 Posters 26.9k Views 3 Watching
      JMac @sdetweil
      @sdetweil so I ran e2fsck -f -v /dev/mmcblk0p2
      got a warning about SEVERE filesystem damage.
      went yes and got ]e2fsck : permission denied while trying to open /dev/mmcblk0p2
      you must have r/w access to the filesystem or be root.
      How do I get around this?
      mumblebajM 1 Reply Last reply
      • mumblebajM
        mumblebaj Module Developer @JMac
        @JMac I am sure Sam is probably still sleeping, but you can try sudo e2fsck -f -v /dev/mmcblk0p2. This should run as root user.
        J 1 Reply Last reply
          JMac @mumblebaj
          @mumblebaj when I run that in terminal I get,
          e2fsck 1.46.2 (28-Feb-2021)
          /dev/mmcblk0p2 is mounted.
          e2fsck: cannot continue, aborting.
          Any thoughts, is that image/setup a goner?
          mumblebajM S 2 Replies Last reply
          • mumblebajM
            @JMac You could try systemctl stop udev and then try running it again. My knowledge of these linux things are not that great. Or service udev stop might work. I am leaning towards the card being a goner thought.
              JMac @mumblebaj
              @mumblebaj It would be way easier if I could recover the previous setup but I’m starting to feel like it might be worth starting the entire MM install again, but for me that’s the least interesting parts of Pi builds.
              The files are still available on the old SD card so the card itself isn’t completely kaput.
              edit to add I ran the systemctl stop udev command.
              put in the password of the MM to allow this.
              re ran sudo e2fsck -f -v /dev/mmcblk0p2
              and get the same e2fcsk: cannot continue, aborting error.
              • mumblebajM
                @JMac You can use the scripts from Sam to install MM. You can find them here. Always do a backup of your install with one of Sam’s script as this would save tears in the end. I have been there before and the backup and restore process saved me a few times.
                Scripts can be located here:
                  sdetweil @JMac
                  @JMac you cant whack on a file system if its mounted for access,do
                  df -k
                  will show u the devices and where they are mounted then sudo umount /dev/… what you were using
                  df -k should show it gone
                  then the fsck… commands should work w sudo
                    sdetweil @JMac
                    @JMac if u can get the config, custom
                    css and and listing of the modules ( ls command) we can build the backup/restore files
                      JMac @sdetweil
                      @sdetweil sorry to be dense how do I know what I’m unmounting?
                      am I unmounting /dev/mmcblk0p1?? it says thats mounted on /boot.
                      edit to add,
                      after re running sudo fdisk -l it would appear the old memory card (with my previous MM setup on) is on Disk /dev/sda
                      thats classed as Disk Model: storage device (as it’s mounted in the usb drive atm) does this seem correct? is this the one which needs unmounting?
                        sdetweil @JMac
                        @JMac well mounted means accessible by the filesystem
                        so it’s /dev/sda
                        the usb installed sd card
                        so
                        sudo unmount /dev/sda
                        and then run fsck on that
                          JMac
                          so I run the command sudo umount /dev/sda
                          and get
                          umount: /dev/sda: not mounted.
                          so should now go,
                          e2fsck -f -v /dev/sda
                          not the original
                          e2fsck -f -v mmcblk0p2
                            sdetweil @JMac
                            @JMac correct… you had to find the disk name
                              JMac @sdetweil
                              @sdetweil when i run e2fsck…
                              I get
                              e2fsck: permission denied while trying to open /dev/sda
                                sdetweil @JMac
                                @JMac yes, you must use sudo on both commands unmount and fsck
                                sorry I was unclear
                                normal users should not be able to mess with hardware, so one must act as root
                                  JMac @sdetweil
                                  @sdetweil I run sudo umount…
                                  and get
                                  umount:… not mounted,
                                  then run
                                  sudo e2fsck -f -v /dev/sda
                                  and get
                                  e2fsck 1.46.2 (28-feb-2021)
                                  /dev/sda is in use
                                  efsck: connot continue, aborting.
                                    sdetweil @JMac
                                    @JMac hm… wonder what is using it?
                                    can you open the disks app on the pi from the dedktop menu
                                      JMac @sdetweil
                                      @sdetweil on the home screen I have 2 drive icons under the wastebasket.
                                      one is boot
                                      the other is rootfs
                                      i then have the option to eject these in the file manager
                                        sdetweil @JMac
                                        @JMac there should be that drive on /dev/sda too
                                          JMac @sdetweil
                                          @sdetweil I’m a little confused (I’d imagine thats pretty clear at this point).
                                          i run sudo fdisk -1
                                          and get
                                          Disk /dev/ram0 through to Disk /dev/ram15
                                          the list then has
                                          Disk/dev/mmcblk0: 7.4GiB (my thinking is this is the current/new sd card)
                                          Device
                                          /dev/mmcblk0p1
                                          /dev/mmcblk0p2
                                          Disk /dev/sda:59.69 GiB (I again assume this is the old SD with my original MM setup)
                                          Device
                                          /dev/sda1
                                          /dev/sda/2
                                          end of the list.
                                          does any of that make sense/ is any of it what I’m looking for? I’ve obviously taken out several lines under each of those headers just for space and time typing.
                                            sdetweil @JMac
                                            @JMac yes sda has two partitions boot and rootfs
                                            but you need to run e2fsck on /dev/sda2
                                            e2fsck mean extended version 2, file system check
                                            • 2 / 3
