    Everything was going so well
    52 Posts 4 Posters 26.9k Views 3 Watching
      sdetweil @JMac
      @JMac well mounted means accessible by the filesystem
      so it’s /dev/sda
      the usb installed sd card
      so
      sudo unmount /dev/sda
      and then run fsck on that
        JMac
        so I run the command sudo umount /dev/sda
        and get
        umount: /dev/sda: not mounted.
        so should now go,
        e2fsck -f -v /dev/sda
        not the original
        e2fsck -f -v mmcblk0p2
          sdetweil @JMac
          @JMac correct… you had to find the disk name
          J 1 Reply Last reply
            JMac @sdetweil
            @sdetweil when i run e2fsck…
            I get
            e2fsck: permission denied while trying to open /dev/sda
            you must have r/w access to the filesystem or be root.
              sdetweil @JMac
              @JMac yes, you must use sudo on both commands unmount and fsck
              sorry I was unclear
              normal users should not be able to mess with hardware, so one must act as root
                JMac @sdetweil
                @sdetweil I run sudo umount…
                and get
                umount:… not mounted,
                then run
                sudo e2fsck -f -v /dev/sda
                and get
                e2fsck 1.46.2 (28-feb-2021)
                /dev/sda is in use
                efsck: connot continue, aborting.
                  sdetweil @JMac
                  @JMac hm… wonder what is using it?
                  can you open the disks app on the pi from the dedktop menu
                    JMac @sdetweil
                    @sdetweil on the home screen I have 2 drive icons under the wastebasket.
                    one is boot
                    the other is rootfs
                    i then have the option to eject these in the file manager
                      sdetweil @JMac
                      @JMac there should be that drive on /dev/sda too
                        JMac @sdetweil
                        @sdetweil I’m a little confused (I’d imagine thats pretty clear at this point).
                        i run sudo fdisk -1
                        and get
                        Disk /dev/ram0 through to Disk /dev/ram15
                        the list then has
                        Disk/dev/mmcblk0: 7.4GiB (my thinking is this is the current/new sd card)
                        Device
                        /dev/mmcblk0p1
                        /dev/mmcblk0p2
                        Disk /dev/sda:59.69 GiB (I again assume this is the old SD with my original MM setup)
                        Device
                        /dev/sda1
                        /dev/sda/2
                        end of the list.
                        does any of that make sense/ is any of it what I’m looking for? I’ve obviously taken out several lines under each of those headers just for space and time typing.
                          sdetweil @JMac
                          @JMac yes sda has two partitions boot and rootfs
                          but you need to run e2fsck on /dev/sda2
                          e2fsck mean extended version 2, file system check
                            JMac
                            so should i also run sudo umount /dev/sda2 before running sudo e2fsck -f -v /dev/sda2?
                              sdetweil @JMac
                              @JMac yes
                                JMac @sdetweil
                                @sdetweil so I’ve run sudo umount /dev/sda1 and the same for sda2 and both folders have disappeared off the home screen.
                                which e2fsck do I run if i had to unmount 2 drives?
                                  sdetweil @JMac
                                  @JMac unmount means remove them from normal file system access
                                  the device names still exist
                                  as e2fsck could modify the file system blocks on the drive, you don’t want to do that while you could still copy a file there
                                  so you are passing the hardware name to e2fsck
                                    JMac @sdetweil
                                    @sdetweil so do I run e2fsck -f -v /dev/sda1 or e2fsck -f -v /dev/sda2
                                    or does it not matter?
                                    I’m struggling here to the bigger picture so can’t see the logic of the steps.
                                      sdetweil @JMac
                                      @JMac ok bigger picture, in Linux
                                      hardware devices are named. see the output of ls /dev
                                      disk devices are usually named sd??? where xxx is a letter, and partition number
                                      letter a is the first device b the second etc
                                      sometime in the past the type of storage device was also used as part of the name, scsi, atapi …
                                      for this case they are named sd (storage device)
                                      sda is the first storage device
                                      sda1 is the first partition on the sda device
                                      on those partitions are a logical way of storing data. most linux and all windows devices store file data in sectors, 512 byte chunks called sectors. and then the file system (way of organizing those sectors)
                                      applies some data structure on top. it’s a directory or a file. tables in other sectors build trees of data to describe the entire partition.
                                      there are different layouts depending on vendor and intended use
                                      FAT, exFAT, NTFS EXT3, EXT4, and a host of others.
                                      all is wonderful until some sector or more gets damaged… machine was powered off during write, a hardware failure…
                                      now the filesystem code is confused… says read sector 853, and the bits there will tell it where the next sector is for this file. but the bits don’t point to the right place… Oops
                                      some file systems include a duplicate set of bits do there is an alternative way . some use them only for recovery.
                                      sd card hardware is known for being fragile. it was designed for lots of reads,with few writes. camera picture music file. NOT an os that is waiting logs and other stuff constantly.
                                      anyhow.
                                      to check and correct these kinds of problems with the Linux ext file system we need to run thr fsck program on the raw partition. and make sure that moone else is using it.
                                      unmount takes it out of circulation. no users files open
                                      fsck and e2fsck need to read the raw sectors on the partition, but we just unmounted it.
                                      so we need to provide the hardware name for the program to use.
                                        JMac @sdetweil
                                        @sdetweil Wow, that was a bit to take in but makes sense (I think).
                                        So if I unmount it how do I get the information off it?
                                        what are the steps here?
                                          sdetweil @JMac
                                          @JMac
                                          unmount it
                                          run fsck against it
                                          remount it (hopefully fixed)
                                          then copy your data first thing, DO NOT WRITE TO THE SD CARD
                                          config.js
                                          custom.css
                                          and a list of all the modules in modules (ls *)
                                          if u WANT to try in each module folder do
                                          git remote -v
                                          ```⁷
                                          so we know where it came from
                                          quickest way in each module folder
                                          git remote -v | tail -a ~/module_list
                                          this will list to github source (git remote -v) and append that info  (tail -a) to a known file in your home folder (~ = home)
                                          this is what my backup script does
                                          IF you have any modules that require authentication (run an auth script)
                                          ls *.json while you are there,
                                          you could also run my backup script, from the web page copy/paste  with -s  pointing to the mounted folder MagicMirror
                                          https://github.com/sdetweil/MagicMirror-backup-restore
                                          ...MM_backup -s /media/??????/MagicMirror some gobbleygoop name (tab key will fill it in after the 1st letter)
                                          this will create the MM_backup folder in your logged on user home folder..
                                          and do all the work described above (after the mount)
                                            JMac
                                            had a little crack at this again, the Mrs is bugging me to get “her” mirror back up and running.
                                            So I’ve run sudo umount /dev/sda1
                                            Both drive folders from the mounted (old) SD disappeared from the home screen on the pi as expected.
                                            then run, (and got)
                                            rootfs: recovering journal
                                            superblock needs_recovery flag is clear but journal has data.
                                            Run journal anyway ? YES
                                            e2fsck: unable to set superblock flags on rootfs
                                            rootfs: *********** WARNING: filesytem still has errors *********
                                            • 2 / 3
