    Everything was going so well
    52 Posts 4 Posters 22.3k Views 3 Watching
      sdetweil @JMac
      @JMac you cant whack on a file system if its mounted for access,do
      df -k
      will show u the devices and where they are mounted then sudo umount /dev/… what you were using
      df -k should show it gone
      then the fsck… commands should work w sudo
        sdetweil @JMac
        @JMac if u can get the config, custom
        css and and listing of the modules ( ls command) we can build the backup/restore files
          JMac @sdetweil
          @sdetweil sorry to be dense how do I know what I’m unmounting?
          am I unmounting /dev/mmcblk0p1?? it says thats mounted on /boot.
          edit to add,
          after re running sudo fdisk -l it would appear the old memory card (with my previous MM setup on) is on Disk /dev/sda
          thats classed as Disk Model: storage device (as it’s mounted in the usb drive atm) does this seem correct? is this the one which needs unmounting?
            sdetweil @JMac
            @JMac well mounted means accessible by the filesystem
            so it’s /dev/sda
            the usb installed sd card
            so
            sudo unmount /dev/sda
            and then run fsck on that
              JMac
              so I run the command sudo umount /dev/sda
              and get
              umount: /dev/sda: not mounted.
              so should now go,
              e2fsck -f -v /dev/sda
              not the original
              e2fsck -f -v mmcblk0p2
                sdetweil @JMac
                @JMac correct… you had to find the disk name
                  JMac @sdetweil
                  @sdetweil when i run e2fsck…
                  I get
                  e2fsck: permission denied while trying to open /dev/sda
                  you must have r/w access to the filesystem or be root.
                    sdetweil @JMac
                    @JMac yes, you must use sudo on both commands unmount and fsck
                    sorry I was unclear
                    normal users should not be able to mess with hardware, so one must act as root
                      JMac @sdetweil
                      @sdetweil I run sudo umount…
                      and get
                      umount:… not mounted,
                      then run
                      sudo e2fsck -f -v /dev/sda
                      and get
                      e2fsck 1.46.2 (28-feb-2021)
                      /dev/sda is in use
                      efsck: connot continue, aborting.
                        sdetweil @JMac
                        @JMac hm… wonder what is using it?
                        can you open the disks app on the pi from the dedktop menu
                          JMac @sdetweil
                          @sdetweil on the home screen I have 2 drive icons under the wastebasket.
                          one is boot
                          the other is rootfs
                          i then have the option to eject these in the file manager
                            sdetweil @JMac
                            @JMac there should be that drive on /dev/sda too
                              JMac @sdetweil
                              @sdetweil I’m a little confused (I’d imagine thats pretty clear at this point).
                              i run sudo fdisk -1
                              and get
                              Disk /dev/ram0 through to Disk /dev/ram15
                              the list then has
                              Disk/dev/mmcblk0: 7.4GiB (my thinking is this is the current/new sd card)
                              Device
                              /dev/mmcblk0p1
                              /dev/mmcblk0p2
                              Disk /dev/sda:59.69 GiB (I again assume this is the old SD with my original MM setup)
                              Device
                              /dev/sda1
                              /dev/sda/2
                              end of the list.
                              does any of that make sense/ is any of it what I’m looking for? I’ve obviously taken out several lines under each of those headers just for space and time typing.
                                sdetweil @JMac
                                @JMac yes sda has two partitions boot and rootfs
                                but you need to run e2fsck on /dev/sda2
                                e2fsck mean extended version 2, file system check
                                  JMac
                                  so should i also run sudo umount /dev/sda2 before running sudo e2fsck -f -v /dev/sda2?
                                    sdetweil @JMac
                                    @JMac yes
                                      JMac @sdetweil
                                      @sdetweil so I’ve run sudo umount /dev/sda1 and the same for sda2 and both folders have disappeared off the home screen.
                                      which e2fsck do I run if i had to unmount 2 drives?
                                        sdetweil @JMac
                                        @JMac unmount means remove them from normal file system access
                                        the device names still exist
                                        as e2fsck could modify the file system blocks on the drive, you don’t want to do that while you could still copy a file there
                                        so you are passing the hardware name to e2fsck
                                          JMac @sdetweil
                                          @sdetweil so do I run e2fsck -f -v /dev/sda1 or e2fsck -f -v /dev/sda2
                                          or does it not matter?
                                          I’m struggling here to the bigger picture so can’t see the logic of the steps.
                                            sdetweil @JMac
                                            @JMac ok bigger picture, in Linux
                                            hardware devices are named. see the output of ls /dev
                                            disk devices are usually named sd??? where xxx is a letter, and partition number
                                            letter a is the first device b the second etc
                                            sometime in the past the type of storage device was also used as part of the name, scsi, atapi …
                                            for this case they are named sd (storage device)
                                            sda is the first storage device
                                            sda1 is the first partition on the sda device
                                            on those partitions are a logical way of storing data. most linux and all windows devices store file data in sectors, 512 byte chunks called sectors. and then the file system (way of organizing those sectors)
                                            applies some data structure on top. it’s a directory or a file. tables in other sectors build trees of data to describe the entire partition.
                                            there are different layouts depending on vendor and intended use
                                            FAT, exFAT, NTFS EXT3, EXT4, and a host of others.
                                            all is wonderful until some sector or more gets damaged… machine was powered off during write, a hardware failure…
                                            now the filesystem code is confused… says read sector 853, and the bits there will tell it where the next sector is for this file. but the bits don’t point to the right place… Oops
                                            some file systems include a duplicate set of bits do there is an alternative way . some use them only for recovery.
                                            sd card hardware is known for being fragile. it was designed for lots of reads,with few writes. camera picture music file. NOT an os that is waiting logs and other stuff constantly.
                                            anyhow.
                                            to check and correct these kinds of problems with the Linux ext file system we need to run thr fsck program on the raw partition. and make sure that moone else is using it.
                                            unmount takes it out of circulation. no users files open
                                            fsck and e2fsck need to read the raw sectors on the partition, but we just unmounted it.
                                            so we need to provide the hardware name for the program to use.
                                            • 2 / 3
