    MMM_Bluelinky Fails Overnight
    3 Posts 2 Posters 805 Views 2 Watching
    • R
      rrslssr
      My instance of MMM-Bluelinky is failing to refresh at the end of the day. There are no errors listed in the Console. Only that the Bluelinky module refresh pattern just stops:
      I’ve truncated the rest of the logfile as it does not show anything different until the very end:
      While the Bluelinky module is not being updated, the other modules appear to work just fine: clock, calendar, weather-current, weather-forecast, and news feed.
      The Bluelinky module will update and display correctly after restarting MM or rebooting the system. I have tried altering its refreshInterval and wakeOn settings but nothing has worked.
      My next test is going to be to disable the AutoDimmer and see what happens.
      Any help or direction would be appreciated.
        sdetweil @rrslssr
        @rrslssr next Update 63139985 is 17 hours from 4:48 am.
        or 21:48… which is not yet… I don’t know why not a full day
        R 1 Reply Last reply
        • R
          rrslssr @sdetweil
          @sdetweil Isn’t that the timeframe for the AutoDimmer? The BlueLinky config is setup by default to update every hour, which it does until sometime in the evening. I just checked the monitor and it was updated 6 minutes ago.
          I rebooted it this morning, so I know that BlueLinky’s updated at least twice today.:
