    MMM-CalendarEx3 use description instead of summary of ics file
    4 Posts 3 Posters 1.0k Views 3 Watching
    • N
      nhweb
      Hello,
      is it possible to use the description instead of the summary of a ics file?
      In my case, the summary is unfortunately very general, so the correct information is in the description. Unfortunately, I currently only have appointments that are labeled “General”.
      Would it be possible with eventTransformer?
      KR Holger
      • M
        MMRIZE @nhweb
        @nhweb
        /* MMM-CalendarExt3 config in config/config.js */
        	eventTransformer: (event) => {
        		if (event.calendarName === 'test' && event.description) { // If event is from 'test' calendar and has description,
        			event.title = event.description
        		return event;
        9:00 PM event was originally titled as ‘Singleday Event’
        • M
          MMRIZE @nhweb
          @nhweb possible with eventTransformer
          @sdetweil The default calendar broadcasts description and location info fortunately.
          • N
            nhweb @MMRIZE
            @MMRIZE
            Ok, thank you.
            Do you have an example how to do this?
            Summary is allways “Allgemein” with different descriptions.
            • M
              MMRIZE @nhweb
              @nhweb
              		return event;
