    calendar (icloud) not loading after last MM Update
    18 Posts 4 Posters 5.7k Views 4 Watching
      sdetweil @sil3ntstorm
      @sil3ntstorm on Linux most commands when successful set the return code and just exit
      do now reinstall node-ical again
        sil3ntstorm
        I have now restarted the PI and it boots up but only up to where MM2 is supposed to start, then this image with sunset or sunrise remains and the MM software does not start. This is in the log file (see below)
        If I deactivate my calendar module everything starts normally.
        The things I was supposed to do yesterday I also did this morning, and I get the same message as yesterday evening
          sil3ntstorm
            sil3ntstorm
            Does it help if I delete the module with the command and then reinstall it?
            cd~/MagicMirror
            rm-rf modules/MMM-MyCalendar
              @sil3ntstorm said in calendar (icloud) not loading after last MM Update:
              looks like you didn’t do this step
              cd ~/MagicMirror
              npm install node-ical@0.16.1
              which MMM-MyCalendar are you using?
              one I found doesn’t have a node_helper.js
              git remote -v
              in the module folder
                sil3ntstorm @sdetweil
                https://github.com/jclarke0000/MMM-MyCalendar
                  @sil3ntstorm ok, something has happened to the node_modules folder, so time to cleanup
                  do
                  cd ~/MagicMirror
                  sudo rm -rf node-modules
                  npm run install-mm
                    I tried it but these error messages appear. I even completely reinstalled MM, the message you see below comes after I enter the command
