    calendar (icloud) not loading after last MM Update
    18 Posts 4 Posters 7.5k Views 4 Watching
      sil3ntstorm
      I had a power outage while executing the command, now I get this error message when I try to run it.
      Does anyone know what to do?
        sdetweil @sil3ntstorm
        @sil3ntstorm
        do
        sudo rm -rf node_modules/node-ical
        npm install node-ical@0.16.1
          sil3ntstorm
          the same message
            @sil3ntstorm ah,
            sudo rm -rf node_modules/axios
              sil3ntstorm
              Unfortunately when I enter that nothing happens
                @sil3ntstorm on Linux most commands when successful set the return code and just exit
                do now reinstall node-ical again
                  sil3ntstorm
                  I have now restarted the PI and it boots up but only up to where MM2 is supposed to start, then this image with sunset or sunrise remains and the MM software does not start. This is in the log file (see below)
                  If I deactivate my calendar module everything starts normally.
                  The things I was supposed to do yesterday I also did this morning, and I get the same message as yesterday evening
                    sil3ntstorm
                      sil3ntstorm
                      Does it help if I delete the module with the command and then reinstall it?
                      cd~/MagicMirror
                      rm-rf modules/MMM-MyCalendar
                        @sil3ntstorm said in calendar (icloud) not loading after last MM Update:
                        looks like you didn’t do this step
                        which MMM-MyCalendar are you using?
                        one I found doesn’t have a node_helper.js
                        git remote -v
                        in the module folder
                          sil3ntstorm @sdetweil
                          https://github.com/jclarke0000/MMM-MyCalendar
                            @sil3ntstorm ok, something has happened to the node_modules folder, so time to cleanup
                            do
                            sudo rm -rf node-modules
                            npm run install-mm
                              I tried it but these error messages appear. I even completely reinstalled MM, the message you see below comes after I enter the command
