    calendar (icloud) not loading after last MM Update
    18 Posts 4 Posters 7.6k Views 4 Watching
      Chazzer
      hi together,
      Does anyone have a tip? I’ve already replaced the public URL. Restarting PM2 also didn’t work.
                              header: "timmi Termine",
                                      displaySymbol: false,
                                      maximumEntries: 10,
                                      maxTitleLength: 18,
                                      maximumNumberOfDays: 30,
                                      timeFormat: "abolute",
                                      dateFormat:"MMM Do HH:MM",
                                                      fetchInterval: 300000,
                                                      maximumEntries: 10,
                                                      maxTitleLength: 15,
                                                      url: "webcal://p106-caldav.icloud.com/........>
      C mumblebajM 2 Replies Last reply
        Chazzer @Chazzer
        Update: When checking the configuration for the calendar module in the value of timeFormat. Instead of ‘abolute’, it should be ‘absolute’. I corrected the timeFormat. Unfortunately, there’s no improvement; it’s not loading the calendar.
        S C 2 Replies Last reply
          sdetweil @Chazzer
          @Chazzer install the older parser
          npm install node-ical@0.16.1
            Chazzer @Chazzer
            @sdetweil That’s the solution! Installed npm install node-ical@0.16.1 and then executed pm2 restart MagicMirror. Thank you so much!
            • mumblebajM
              mumblebaj Module Developer @Chazzer
              @Chazzer said in calendar (icloud) not loading after last MM Update:
              timeFormat: “abolute”,
              This doesn’t look right either. Think it should be “absolute” and not “abolute”
                sil3ntstorm
                I had a power outage while executing the command, now I get this error message when I try to run it.
                Does anyone know what to do?
                  sdetweil @sil3ntstorm
                  @sil3ntstorm
                  do
                  sudo rm -rf node_modules/node-ical
                    sil3ntstorm
                    the same message
                      @sil3ntstorm ah,
                      sudo rm -rf node_modules/axios
                        sil3ntstorm
                        Unfortunately when I enter that nothing happens
                          @sil3ntstorm on Linux most commands when successful set the return code and just exit
                          do now reinstall node-ical again
                            sil3ntstorm
                            I have now restarted the PI and it boots up but only up to where MM2 is supposed to start, then this image with sunset or sunrise remains and the MM software does not start. This is in the log file (see below)
                            If I deactivate my calendar module everything starts normally.
                            The things I was supposed to do yesterday I also did this morning, and I get the same message as yesterday evening
                              sil3ntstorm
                                sil3ntstorm
                                Does it help if I delete the module with the command and then reinstall it?
                                cd~/MagicMirror
                                rm-rf modules/MMM-MyCalendar
                                  @sil3ntstorm said in calendar (icloud) not loading after last MM Update:
                                  looks like you didn’t do this step
                                  which MMM-MyCalendar are you using?
                                  one I found doesn’t have a node_helper.js
                                  git remote -v
                                  in the module folder
                                    sil3ntstorm @sdetweil
                                    https://github.com/jclarke0000/MMM-MyCalendar
                                      @sil3ntstorm ok, something has happened to the node_modules folder, so time to cleanup
                                      do
                                      sudo rm -rf node-modules
                                      npm run install-mm
                                        I tried it but these error messages appear. I even completely reinstalled MM, the message you see below comes after I enter the command
