    calendar (icloud) not loading after last MM Update
    18 Posts 4 Posters 5.5k Views 4 Watching
      Chazzer
      hi together,
      Does anyone have a tip? I’ve already replaced the public URL. Restarting PM2 also didn’t work.
                              header: "timmi Termine",
                                      displaySymbol: false,
                                      maximumEntries: 10,
                                      maxTitleLength: 18,
                                      maximumNumberOfDays: 30,
                                      timeFormat: "abolute",
                                      dateFormat:"MMM Do HH:MM",
                                                      fetchInterval: 300000,
                                                      maximumEntries: 10,
                                                      maxTitleLength: 15,
                                                      url: "webcal://p106-caldav.icloud.com/........>
      C mumblebajM 2 Replies Last reply Reply Quote 0
        Chazzer @Chazzer
        Update: When checking the configuration for the calendar module in the value of timeFormat. Instead of ‘abolute’, it should be ‘absolute’. I corrected the timeFormat. Unfortunately, there’s no improvement; it’s not loading the calendar.
        S C 2 Replies Last reply Reply Quote 0
          sdetweil @Chazzer
          @Chazzer install the older parser
          npm install node-ical@0.16.1
            Chazzer @Chazzer
            @sdetweil That’s the solution! Installed npm install node-ical@0.16.1 and then executed pm2 restart MagicMirror. Thank you so much!
            • mumblebajM Offline
              mumblebaj Module Developer @Chazzer
              @Chazzer said in calendar (icloud) not loading after last MM Update:
              timeFormat: “abolute”,
              This doesn’t look right either. Think it should be “absolute” and not “abolute”
                sil3ntstorm
                I had a power outage while executing the command, now I get this error message when I try to run it.
                Does anyone know what to do?
                  sdetweil @sil3ntstorm
                  @sil3ntstorm
                  do
                  sudo rm -rf node_modules/node-ical
                    sil3ntstorm
                    the same message
                      @sil3ntstorm ah,
                      sudo rm -rf node_modules/axios
                        sil3ntstorm
                        Unfortunately when I enter that nothing happens
