    calendar (icloud) not loading after last MM Update
    18 Posts 4 Posters 5.1k Views 4 Watching
    • mumblebajM Offline
      mumblebaj Module Developer @Chazzer
      @Chazzer said in calendar (icloud) not loading after last MM Update:
      timeFormat: “abolute”,
      This doesn’t look right either. Think it should be “absolute” and not “abolute”
        sil3ntstorm
        I had a power outage while executing the command, now I get this error message when I try to run it.
        Does anyone know what to do?
          sdetweil @sil3ntstorm
          @sil3ntstorm
          do
          sudo rm -rf node_modules/node-ical
          npm install node-ical@0.16.1
            sil3ntstorm
            the same message
              @sil3ntstorm ah,
              sudo rm -rf node_modules/axios
                sil3ntstorm
                Unfortunately when I enter that nothing happens
                  @sil3ntstorm on Linux most commands when successful set the return code and just exit
                  do now reinstall node-ical again
                    sil3ntstorm
                    I have now restarted the PI and it boots up but only up to where MM2 is supposed to start, then this image with sunset or sunrise remains and the MM software does not start. This is in the log file (see below)
                    If I deactivate my calendar module everything starts normally.
                    The things I was supposed to do yesterday I also did this morning, and I get the same message as yesterday evening
                      sil3ntstorm
                        sil3ntstorm
                        Does it help if I delete the module with the command and then reinstall it?
                        cd~/MagicMirror
                        rm-rf modules/MMM-MyCalendar
