    Unexpected token error
    3 Posts 2 Posters 696 Views 2 Watching
    • Z Offline
      zalgo
      Hi, whenever I do a config check through npm, I get an error saying “Line 127 column 2: Parsing error: Unexpected token ;”. When I go to check where this line is, it is at the end of the config, which has this
                      height: "720" ,
                      width: "1200" ,
                      quality: "100" ,
                      displayResult: "true" ,
                      device: "null" ,
                      shootMessage: "Smile!" ,
                      displayCountdown: "true" ,
                      resultDuration: "500 * 5" ,
      Any help would be appreciated.
        sdetweil @zalgo
        @zalgo 99% of the time Unexpected token means the line before the reported line is missing a trailing comma.
        I don’t see that here. but you have other problems
        the javascript rules are
        the thing the left of : does not need quotes, unless it contains a non-alpha character
        the thing to the right does NOT need quotes IF it is a number, an formula w numbers, or true or false , OR its a structure start { or array start [,
        otherwise it does need quotes
        your “500 * 5” is a formula and js will calculate that
          sdetweil @zalgo
          @zalgo because the error is end of file, it means it is confused.
          look at the config.js.sample
