    set the calendar day to a short version
    17 Posts 4 Posters 6.4k Views 4 Watching
      skyzuma
      sry but i am not a native en …
      if its possible to set the day of an calendar entry to a short version? The problem is that the entry with a day and a time are bigger as the table / cell and it will oversize all … but if we use “mon” (and also an the correct translation) instead of monday would it will fit …
      • G
        greedyvegan @skyzuma
        @skyzuma
        check out this site
        https://www.npmjs.com/package/dateformat
        then play around with these settings
          skyzuma
          sorry but i am not a programmer … idk what this is meaning …
          • bugsounetB bugsounet referenced this topic on
          • G
            @skyzuma said in set the calendar day to a short version:
            you and I are not programmers, but we’re programming.
            the link I sent tells you about date formats.
            you can match their list of date formats for what you have
            and then use what they mention to give you what you want.
            the area you want to change is in the calendar.js file
            but add it to the config file of the module
            header:
            position:
            			symbol: "calendar-check",
                                    dateEndFormat: "the date format you want",
            I’ve learned that SOMETIMES the people on the forum can just give you the slice of cake, but then you’ll be back for another slice.
            other times, you’ll receive the cake recipe.
            • mumblebajM
              mumblebaj Module Developer @greedyvegan
              @greedyvegan said in set the calendar day to a short version:
              calendar.js
              Never modify the module code directly. You override settings in config/config.js. For css you override it in the css/custom.css, but never change the module code. This will cause issues when upgrading to the latest versions.
              G 1 Reply Last reply Reply Quote 1
              • G
                greedyvegan @mumblebaj
                @mumblebaj
                thank you
                  skyzuma @greedyvegan
                  and now? what i need to change in the configs.js?
                  • G
                    @skyzuma
                    what you want to modify is listed in calender.js
                    dateEndFormat
                    in the file config.js change your module’s config section
                    (look at the red font)
                    header:
                    position:
                    **config**: {
                      its not:
                      calender.js > dateEndFormat = “LT”
                      https://www.npmjs.com/package/dateformat > there is no “dateEndFormat”, only “dateFormat” and no “LT”, what means LT?
                      and there is no example of what i need … if i add the calendar module to MM there is a table with 2 cells with this informations:
                      name of the event : “full dayname of the week” at 00:00 … and this full dayname i need to a shorter verion … on a german language this name is much much longer …
                        sdetweil @skyzuma
                        @skyzuma the calendar module like many others, has a lot of configuration options.
                        the design of MagicMirror provides for a module to set default values, that can be overridden by the user independantly., only if they need to change from the options default value.
                        if you look at the sample config.js, the clock and compliments modules don’t list any config options, as they are using the defaults set by those modules.
                        the documentation should list all of the options for a module, and their default values.
                        i see that the doc for calendar has lost quite a bit of that info, and have opened an issue to get this resolved.
                        dateEndFormat is missing from the doc. its default value is ‘LT’
                        calendar uses the moment library for date processing, including formatting output
                        see
                        https://momentjscom.readthedocs.io/en/latest/moment/04-displaying/01-format/
                        LT is shorthand for ‘h:mm A’, which means
                        h - hour, 12 hour format, no leading zero
                        mm - minutes, leading 0 to make 2 numbers always
                        A - am or pm, capitalized
                        colon and space are treated as literal characters in the output, any characters not used by formst to specify the formatting options may be used as literals
                        by specifying the dateEndFormat in config.js, the execution will use your definition for that option instead of the modules default value (‘LT’)
                          skyzuma @sdetweil
                          if i understand all correct so i need to change in my case not “dateEndFormat” … i need to change “dateFormat: “MMM Do”,” or “fullDayEventDateFormat: “MMM Do”,” to change the name of the week to a shorter version, correct?
                          but what means “MMM Do” ? i cant see on both site this format … and if i see this correct, the cell contais dateFormat + dateEndFormat = MMM Do + LT, or iam wrong?
                            sdetweil @skyzuma
                            @skyzuma if you read the formatting options link i provided in the last post, you would see
                            the MMM means the 3 letter english month name
                              skyzuma @sdetweil
                              thats correct but i need ONLY a short day name for an event with an time. the next event is “Friday at 15:30” … but i need “Fri at 15:30” - its “ddd” - but where i set this? i cant change “dateFormat” or “dateEndFormat” that will change ALL i think
                              MMM Do is important for evnets in a few weeks / month like “May 14th”
                              LT is ONLY the time on an event on a day
                              i think this cant change in the config.js … i think this need to be changed in the source code or maybe as an option, idk …
                                skyzuma @sdetweil
                                i think my “problem” is on calendar.js:455 - nextWeek: “dddd” … this need an option to set this to “ddd” for a short version … ive testet it to set this in config.js but there are no changes after MM restart …
                                S 3 Replies Last reply Reply Quote 0
                                  sdetweil @skyzuma
                                  @skyzuma show the config.js settings for calendar, xxx out the url but dont change anything else
                                  there are 3 format
                                  dateFormat is the event START date/time, when NOT a full day event
                                  dateEndFormat is event END date/time, when NOT a full day event
                                  fullDateFormat is for the date when the event IS a full date event (has no time)
                                  spelling case matters. mm is case sensitive
                                    sdetweil @skyzuma
                                    open an issue on github for magicmirror
                                      sdetweil @skyzuma
                                      yes, only variables defined in the defaults section of the modulename.js are addressable and over-ridable via config.js
