    Weather Module
    7 Posts 2 Posters 1.1k Views 2 Watching
      jpcalka
      Hi
      I use the default weather module the temperature shows in Celsius how do I change to show Fahrenheit.
        jpcalka @sdetweil
        @sdetweil what is the line of code that i need to input to get Fahrenheit and where in config.js do I put this in thanks
          sdetweil @jpcalka
          @jpcalka weather uses the global units: setting in config.js
          default is metric, imperial is the other value option
          the weather module also has a units property, using the default as its initial value,
          you can change it independantly
            jpcalka @sdetweil
              sdetweil @jpcalka
              @jpcalka i am a teacher not a doer.
              i gave you the name of the property,
              and its current value, in config.js
              please read the file and show me the line as it is
                jpcalka @sdetweil
                @sdetweil hi I figured it out thanks
                  jpcalka
                  Hi This Issue has been resolved , but i do not know how to change it to resolved
                    sdetweil @jpcalka
                    @jpcalka click the 3 dots to the right of the post that solves the problem, and select mark this…
