    i upgraded npm and node now mirror not auto starting
    5 Posts 2 Posters 935 Views 2 Watching
    • arora1mayankA Offline
      arora1mayank
      TypeError: Class extends value #<Object> is not a constructor or null
          at Object.<anonymous> (/usr/lib/node_modules/npm/node_modules/tar/lib/read-entry.js:91:4)
          at Module._compile (node:internal/modules/cjs/loader:1198:14)
          at Object.Module._extensions..js (node:internal/modules/cjs/loader:1252:10)
          at Module.load (node:internal/modules/cjs/loader:1076:32)
          at Function.Module._load (node:internal/modules/cjs/loader:911:12)
          at Module.require (node:internal/modules/cjs/loader:1100:19)
          at require (node:internal/modules/cjs/helpers:119:18)
          at Object.<anonymous> (/usr/lib/node_modules/npm/node_modules/tar/lib/pack.js:27:19)
        sdetweil @arora1mayank
        @arora1mayank can you do
        sudo npm install -g pm2
        to upgrade pm2
        arora1mayankA 1 Reply Last reply Reply Quote 0
          arora1mayank @sdetweil
          @sdetweil but even npm start showed this error
            @arora1mayank show more of the error output…
            also output of
            uname -a
            lsb_release -a
            node -v
            npm -v
              @arora1mayank after upgrade of node and npm did you rerun
              npm run install-mm
