    MP3 Player
    59 Posts 5 Posters 21.0k Views 4 Watching
      sdetweil @bachoo786
      @bachoo786 I did not look at the better method… cause I don’t know what that means.
      I wasn’t looking at design, only syntax
        bachoo786 @sdetweil
        @sdetweil ok I will try and explain the “better” method:
        I’m basically trying to add a playlist feature to the MP3 player module I’m working on. My initial setup involved adding a songList to MP3Player.js, which lists all the songs—.mp3 files—in the ‘music’ folder of the module. I’ve also added a second folder, ‘music2’, to categorize songs by artist. Each artist’s name is tagged with an ‘h2’ in the CSS, for both songList and songList2.
        However, this setup becomes cumbersome because it requires repeating the process for multiple artists, creating many folders and modifying the code each time for songList3, songList4, etc.
        I thought a better approach would be to have one ‘music’ folder with subfolders for each artist containing their songs. This way, the module would display artists on the frontend, and clicking an artist’s name would show the songs in their folder.
        I did start on this more streamlined method, but it proved challenging, so I reverted to the simpler, original method which we’ve been discussing since yesterday, as that uses a “single” songList displaying songs from the ‘music’ folder and has been working for me. So I have been trying to add another “songList2” to add more artists and their respective music.
        I hope that makes sense?
          sdetweil @bachoo786
          @bachoo786 ok. I saw the song list 2 and 3, and said
          these should be arrays of songlist[][]
          but now that u add by artist it would be a hash of hashes
          songlist{artist{album}{song}}
          so you could access it with
          songlist[“artistname”][“album1”][song1"]
          or
          songlist[song_info]
          where song_info is a structure
          { artist_name:“…”, albums[{name:“…”, songs:[{…}]]}
            bachoo786 @sdetweil
            @sdetweil sorry to mess with your head but I have been working on this for the last 3 hours and have come up with the following that should show the folders on the front end and when any folder is clicked it should reveal the mp3 files. the issue I am facing is that I am having no errors whatsoever but the module will just not show on the front end. I am pulling my hair out now !
            these are my files:
            node_helper.js:
            var NodeHelper = require('node_helper');
            const Fs = require('fs');
                start: function() {
                    console.log("Loaded MP3Player node_helper");
                    var self = this;
                    if (notification === 'SOURCE_MUSIC') {
                        const musicPath = payload.musicPath;
                        const extensions = payload.extensions;
                        Fs.readdir(musicPath, (err, folders) => {
                            if (err) {
                                console.error("Error reading music directory:", err);
                                self.sendSocketNotification('ERROR', {message: "Error reading music directory"});
                            } else {
                                const musicData = folders.map(folder => ({
                                    folderName: folder,
                                    songs: Fs.readdirSync(`${musicPath}/${folder}`).filter(file => self.checkExt(file, extensions))
                                self.sendSocketNotification("RETURNED_MUSIC", { musicData: musicData });
                checkExt: function(file, ext) {
                    return ext.some(extension => file.toLowerCase().endsWith(extension));
            MMM-MP3Player.js:
            var MP3;
            var substr;
            Module.register("MMM-MP3Player", {
              defaults: {
                songs: [],
                musicPath: "modules/MMM-MP3Player/music",
                extensions: ["mp3", "wma", "acc", "ogg"],
                songs: null,
                autoPlay: false,
                random: false,
              audio: null,
              songTitle: null,
              mediaPlayer: null,
              dataAvailable: true,
              curSong :0,
              curLength : 0,
              time: null,
              play: null,
              firstTime: true,
              substr: null,
              getStyles: function(){
                return ["MMM-MP3Player.css", "font-awesome.css"];
              start: function(){
                MP3 = this;
                console.log("autoPlay configuration:", MP3.config.autoPlay);
                Log.info("Starting module: " + MP3.name);
            getDom: function() {
                if (MP3.config.musicData) {
                    const musicList = MP3.createElement("ul", "musicList", "musicList");
                    MP3.config.musicData.forEach(folderData => {
                        // Folder item
                        const folderItem = MP3.createElement("li", "folderItem", `folderItem-${folderData.folderName}`);
                        folderItem.innerHTML = `
                            <span class="folderName">${folderData.folderName}</span>
                            <i class="fa fa-chevron-down"></i>
                        // Songs list within the folder
                        const songsList = MP3.createElement("ul", "songsList", `songsList-${folderData.folderName}`);
                        songsList.style.display = 'none'; // Initially hide the songs list
                        folderData.songs.forEach(song => {
                            const songItem = MP3.createElement("li", "songItem", `songItem-${song}`);
                            songItem.innerHTML = song.substr(0, song.length - 4);
                            songsList.appendChild(songItem);
                        // Click event listeners
                        folderItem.addEventListener('click', () => {
                            songsList.style.display = songsList.style.display === 'none' ? 'block' : 'none'; // Toggle display
                            folderItem.querySelector('.fa').classList.toggle('fa-chevron-down');
                            folderItem.querySelector('.fa').classList.toggle('fa-chevron-up');
                        songsList.addEventListener('click', (event) => {
                            const clickedSongItem = event.target;
                            if (clickedSongItem.classList.contains('songItem')) {
                                const songName = clickedSongItem.innerText;
                                const folderName = folderData.folderName;
                                MP3.playSong(folderName, songName);
                        folderItem.appendChild(songsList);
                        musicList.appendChild(folderItem);
                    wrapper.appendChild(musicList);
                    // Add the rest of the existing code...
                    MP3.mediaPlayer = MP3.createElement("div", "mediaPlayer", "mediaPlayer");
                    MP3.audio = MP3.createElement("audio", "audioPlayer", "audioPlayer");
                    MP3.audio.addEventListener("loadeddata", () => {
                        MP3.dataAvailable = true;
                        MP3.curLength = MP3.audio.duration;
                        MP3.updateDurationLabel();
                    MP3.audio.addEventListener("ended", () => {
                        Log.log(" play ended")
                        MP3.audio.currentTime = 0;
                        if(MP3.config.autoPlay)
                            MP3.loadNext(MP3.config.random)
                        else
                            MP3.mediaPlayer.classList.toggle("play");
            MP3.audio.addEventListener("timeupdate", () => {
                    MP3.mediaPlayer.appendChild(MP3.audio);
                    // Add the rest of the controls to MP3.mediaPlayer
                    var controls = MP3.createElement("div", "controls", false);
                    MP3.songTitle = MP3.createElement("span", "title", "songTitle");
                    MP3.setCurrentSong(MP3.curSong);
                    controls.appendChild(MP3.songTitle);
                    var discArea = MP3.createElement("div", "discarea", false);
                    discArea.appendChild(MP3.createElement("div", "disc", false));
                    var stylus = MP3.createElement("div", "stylus", false);
                    stylus.appendChild(MP3.createElement("div", "pivot", false));
                    stylus.appendChild(MP3.createElement("div", "arm", false));
                    stylus.appendChild(MP3.createElement("div", "head", false));
                    discArea.appendChild(stylus);
                    MP3.mediaPlayer.appendChild(discArea);
                  var buttons = MP3.createElement("div", "buttons", false);
                  //  Previous Button
                  var prev = MP3.createButton("back", "prevButton", "fa fa-backward");
                  prev.addEventListener("click", () => {
                    MP3.dataAvailable = false;
                    MP3.loadNext(MP3.config.random);
                    MP3.audio.play();
                    MP3.play.getElementsByTagName('i')[0].className = "fa fa-pause";
                  }, false),
                  buttons.appendChild(prev);
                  //  Play Button
                  MP3.play = MP3.createButton("play", "playButton", "fa fa-play");
                  MP3.play.addEventListener("click", () => {
                    if (MP3.audio.paused) {
                      setTimeout(() => {
                        MP3.audio.play();
                      }, 300);
                      MP3.timer = setInterval(MP3.updateDurationLabel, 100);
                    } else {
                      //MP3.loadNext(MP3.config.random);
                      MP3.play.getElementsByTagName('i')[0].className = "fa fa-play";
                      clearInterval(MP3.timer);
                      MP3.audio.pause();
                  }, false);
                  buttons.appendChild(MP3.play);
                  //  Stop Button
                  var stop = MP3.createButton("stop", "stopButton", "fa fa-stop");
                  stop.addEventListener("click", () => {
                    MP3.mediaPlayer.classList.remove("play");
                    MP3.audio.pause();
                  }, false);
                  buttons.appendChild(stop);
                  //  Next Button
                  var next = MP3.createButton("next", "nextButton", "fa fa-forward");
                  next.addEventListener("click", () => {
                  }, false);
                  buttons.appendChild(next);
                    controls.appendChild(buttons);
                    var subControls = MP3.createElement("div", "subControls", false);
                    var duration = MP3.createElement("span", "duration", "currentDuration");
                    duration.innerHTML = "00:00" + "&nbsp&nbsp&nbsp";
                    subControls.appendChild(duration);
                    var volumeSlider = MP3.createElement("input", "volumeSlider", "volumeSlider");
                    volumeSlider.type = "range";
                    volumeSlider.min = "0";
                    volumeSlider.max = "1";
                    volumeSlider.step = "0.01";
                    volumeSlider.addEventListener("input", () => {
                        MP3.audio.volume = parseFloat(volumeSlider.value);
                    }, false);
                    subControls.appendChild(volumeSlider);
                    controls.appendChild(subControls);
                    MP3.mediaPlayer.appendChild(controls);
                    wrapper.appendChild(MP3.mediaPlayer);
                if(MP3.firstTime && MP3.config.autoPlay){
                    console.log("First time and autoPlay are true. Setting firstTime to false.");
                    MP3.firstTime=false;
                return wrapper;
            playSong: function(folderName, songName) {
                const songPath = MP3.config.musicPath + '/' + folderName + '/' + songName;
                MP3.audio.src = songPath;
                MP3.songTitle.innerHTML = songName;
                MP3.audio.play();
              createElement: function(type, className, id){
                var elem = document.createElement(type);
                if(className) elem.className = className;
                if(id)  elem.id = id;
                return elem;
              createButton: function(className, id, icon){
                var button = document.createElement('button');
                button.className = className;
                button.id = id;
                var ico = document.createElement("i");
                ico.className = icon;
                button.appendChild(ico);
                return button;
            updateDurationLabel: function() {
              var duration = document.getElementById('currentDuration');
              if (MP3.dataAvailable && MP3.audio.duration > 0) {
                duration.innerText = MP3.parseTime(MP3.audio.currentTime) + " / " + MP3.parseTime(MP3.audio.duration);
              } else {
                duration.innerText = "00:00 / 00:00";
              parseTime: function(time){
                const minutes = Math.floor(time / 60)
                const seconds = Math.floor(time - minutes * 60)
                const secondsZero = seconds < 10 ? "0" : ""
                const minutesZero = minutes < 10 ? "0" : ""
                return minutesZero + minutes.toString() + ":" + secondsZero + seconds.toString()
              setCurrentSong: function(index){
                  if(MP3.audio!= undefined){
                    MP3.audio.src = MP3.config.musicPath + '/' + MP3.config.songs[index];
                    MP3.songTitle.innerHTML = MP3.config.songs[index].substr(0, MP3.config.songs[index].length - 4);
                    MP3.curSong = index;
              loadNext: function(next){
               let index=0;
                  console.log("loadNext: Autoplay:", MP3.config.autoPlay); // Add this line for logging
                  MP3.audio.pause();
                  if(next)  index= (MP3.curSong + 1) % MP3.config.songs.length;
                  else      index = (MP3.curSong - 1) < 0 ? MP3.config.songs.length - 1 : MP3.curSong - 1;
                  MP3.setCurrentSong(index);
                  MP3.audio.play();
              notificationReceived: function (notification, payload) {
                if(notification === "ALL_MODULES_STARTED")
            		  MP3.sendSocketNotification('SOURCE_MUSIC', MP3.config);
              socketNotificationReceived: function(notification, payload){
                if(notification === "RETURNED_MUSIC")
                  MP3.config.songs = payload.songs;
                  // set the initial song index
                  MP3.setCurrentSong(0);
                  // paint the player
                  MP3.updateDom(2);
            MMM-MP3Player.css:
            @import url("https://fonts.googleapis.com/css?family=Roboto"); /* Simpler, modern font */
            .MMM-MP3Player .songInfo {
                flex: 1; /* Fill half of the available space */
                padding: 20px;
                font-family: 'Roboto', sans-serif;
            .MMM-MP3Player .songTitle {
                font-size: 4em;
                font-weight: bold;
                color: #333; /* Darker text */
                overflow: hidden;
                text-overflow: ellipsis;
                white-space: nowrap;
            .MMM-MP3Player .container {
                position: relative; /* Add this if not present */
                /* ...other styles... */
            .MMM-MP3Player .songsList {
                position: absolute;
                left: 10px; /* Adjust to align correctly, can be in px or % */
                top: -360px;  /* Adjust to align correctly, can be in px or % */
                width: 50%; /* Adjust to not exceed the container width */
                max-width: calc(100% - 40px); /* Subtract total horizontal padding */
                align-items: center;
                padding: 20px;
                box-sizing: border-box;
                font-size: 2em;
                font-weight: bold;
                color: #FFF;
                overflow: hidden;
                z-index: 1000;
                background-image:
                    linear-gradient(
                        to bottom,
                        rgba(255, 255, 255, 0.8) 0%,
                        rgba(255, 255, 255, 0.75) 25%,
                        rgba(255, 255, 255, 0.6) 50%,
                        rgba(255, 255, 255, 0.4) 75%,
                        rgba(255, 255, 255, 0.3) 100%
                    url('images/qsonglist.png');
                background-size: cover;
                background-position: center;    border-radius: 20px;
                border: 1px solid rgba(255, 255, 255, 0.3);
                backdrop-filter: blur(15px);
                -webkit-backdrop-filter: blur(15px);
                box-shadow: 0 8px 24px rgba(0, 0, 0, 0.2);
            .MMM-MP3Player .mediaPlayer {
                position: absolute;
                right: 0;  /* Adjust as needed to align to the right */
                top: -130px;       /* Aligns to the top of the container */
                width: 50%;   /* Or whatever width you require */
                padding: 20px;
                justify-content: center;
                z-index: 1000;
            .MMM-MP3Player .controls {
                width: 80%;
                margin-top: 20px;
            .MMM-MP3Player .buttons button {
                background-color: #4CAF50; /* Example: Green for modern feel */
                color: white;
                border: none;
                border-radius: 50%;
                margin-right: 10px;
                font-size: 1.2em;
                width: 50px;
                height: 50px;
                box-shadow: 0 2px 5px rgba(0,0,0,0.3); /* Adds depth */
            .MMM-MP3Player .buttons button:hover {
                background-color: #3e8e41; /* Darker green on hover */
                cursor: pointer;
            in my config.js:
            I have added it this way:
                module: "MMM-MP3Player",
                position: "bottom_center",
                "pages": {"Audio": "bottom_center"},
            				autoPlay: false,
            				random: false,
            				loopList: false,
            Can you tell me what am I doing wrong? thanks
              sdetweil @bachoo786
              @bachoo786 can you please make a git repo of this.
                sdetweil @bachoo786
                @bachoo786 what shows in the developers window?
                  bachoo786 @sdetweil
                  @sdetweil I will .
                  Nothing says everything is loaded including the mp3 player module.
                    sdetweil @bachoo786
                    @bachoo786 well, code and data don’t match
                    config.js
                    defaults
                    getDom()
                        if (MP3.config.musicData) { (and other places)
                    if you use the developers window you can step thru the code
                      bachoo786 @sdetweil
                      @sdetweil here is the repo:
                      https://github.com/bachoo786/MMM-MP3Player
                        sdetweil @bachoo786
                        @bachoo786 you don’t set
                        if (MP3.config.musicData) {  anywhere..  so getDom() returns an empty div
                        I ‘assume’ you meant for the node_helper to send this back
                        but yours socketNotifcationReceived does this
                              MP3.config.songs = payload.songs;  <---  songs is undefined, but musicData is there
                        B B 2 Replies Last reply Reply Quote 0
                          bachoo786 @sdetweil
                          @sdetweil so I made a mistake, i wanted my code to look for the mp3 files automatically in the folders within the music directory.
                          currently I am getting an error in the developer console:
                          Uncaught SyntaxError: Unexpected token ',' (at MMM-MP3Player.js:184:2)
                          its the “,” at the end of
                          return wrapper
                          I am trying to have one ‘music’ folder with subfolders for each artist containing their songs. This way, the module would display artists on the frontend, and clicking an artist’s name would show the songs in their folder, and click on the song would then play the mp3 file.
                          feel like giving up really even though I think I am close
                          S B 3 Replies Last reply Reply Quote 0
                            sdetweil @bachoo786
                            @bachoo786 what did you change?
                            this is a missing } probably
                              sdetweil @bachoo786
                              @bachoo786 well, coding is a challenge sometimes
                              you changed the data coming back from the node helper
                              the code is looking for songs
                              but its a nested struct in musicData
                              so, fix the first thing (the socketNotificationReceived)
                              and then the code crashes later cause you are expecting the data in songs…
                              computers do things fast… they don’t know WHY they are doing it, so can’t ‘fix’ themselves
                                bachoo786 @bachoo786
                                @bachoo786
                                I changed from this:
                                            // Folder item
                                to this:
                                   const fs = require('fs');
                                   const path = require('path');
                                   const musicFolder = path.resolve(MP3.config.musicData.musicPath);
                                   const supportedExtensions = this.defaults.extensions; // Use module's default extensions
                                   fs.readdir(musicFolder, (err, files) => {
                                    if (err) {
                                     // Handle the error - display message to user, etc.
                                    } else {
                                     const musicFiles = files.filter(file => supportedExtensions.includes(path.extname(file).toLowerCase()));
                                     if (musicFiles.length > 0) {
                                      const musicList = MP3.createElement("ul", "musicList");
                                      musicFiles.forEach(musicFile => {
                                       const songItem = MP3.createElement('li', 'songItem');
                                       songItem.innerHTML = musicFile.substr(0, musicFile.length - 4);
                                       songItem.addEventListener('click', () => {
                                        MP3.playSong(musicFile); // Assuming you want to play the song directly
                                       musicList.appendChild(songItem);
                                  sdetweil @bachoo786
                                  @bachoo786 you could say, I have updated the repo, git pull to get the changes…
                                  you need to
                                  git add,
                                  git commit -m and
                                  git push
                                  to update the repo
                                    sdetweil @bachoo786
                                    @bachoo786 said in MP3 Player:
                                    the modulename.js that runs in the browser cannot read files directly, due to security restrictions ( any script could read ALL your files without you knowing)
                                    this is why the node_helper exists…
                                      bachoo786 @sdetweil
                                      @sdetweil said in MP3 Player:
                                      so whats the alternative? I had this MMM-QuranPlayer module that was able to read mp3 files from the folders in the “public” directory which was located in the root folder of the module.
                                        sdetweil @bachoo786
                                        @bachoo786 I’m pretty sure the module used a node_helper
                                        now if you make it a url, then you can fetch it thru the browser… but the server side is actually reading the file
                                        but you could make it a file url
                                        file:///server/path to file
                                        in MagicMirror the server home folder is the MagicMirror folder
                                          BiaGen @sdetweil
                                          Hey @bachoo786, I’ve been following your progress with the folder nesting—it’s a tricky bit of logic to get right in the node_helper, but it’ll be worth it for the cleaner UI!
                                          One thing I noticed while setting up my own music module is that the player looks a lot better if the MP3 metadata (ID3 tags) is actually clean. If the tags are messy, the ‘Artist’ and ‘Title’ fields on the mirror usually end up looking like a jumble of underscores and file extensions.
                                          Since you’re organizing a big library right now, I’ve been using https://editmp3tags.com/ to quickly fix the tags in the browser before dropping them into the music folder. It’s way faster than using a heavy desktop app and helps the module display everything correctly once you get that ‘better method’ logic sorted out.
                                          • 3 / 3
