    PM2 auto start and python virtual environment not playing together
    4 Posts 2 Posters 2.8k Views 2 Watching
    • B
      Brown19
      Hi, I use Tom Hirschberger’s MMM-Temperature to display temp and humidity from an adafruit sht31d. It has a dependency of the Adafruit CircuitPython Library. I’ve upgrade my pi to Bookworm. Python now runs in a virtual environment. I can activate the virtual environment and get everything to work if I launch MM2 in the virtual environment using npm start. It doesn’t work using PM2 start MagicMirror.
      I know you call call python without explicitly activating the environment but I’m not sure what changes need to be made to module.
      Maybe create a systemd unit file to run the the library at startup?
      Ideally, I want the same functionality back; my MM starts on boot and python works normally.
      Has anyone seen this or has a fix?
      Thanks!
        sdetweil @Brown19
        @Brown19 in the script launched by pm2, connect to the virtual environment with the venv command , before launching mm
        if you setup MagicMirror from my script, then the bash script used is
        ~/MagicMirror/installers/mm.sh
        B 1 Reply Last reply
        • B
          Brown19 @sdetweil
          @sdetweil Thanks! That worked. I added a line in mm.sh to connect to the virtual environment before launching mm.
          • B Brown19 has marked this topic as solved on
            sdetweil @Brown19
            @Brown19 from an educational perspective
            the command pm2 info MagicMirror
            would have shown you what program. or script was being launched
            and then, when you open a terminal window, the .profile and .bashrc scripts are run to setup the user environment.
            the .bashrc has the venv command in it
            when pm2 launches a pgm at startup, it is not using a terminal window, so those script are NOT run
            you can also use the source command to load them at any time
            so you could have done
            source .bashrc
            instead of
            venv…
