    HELP WITH MMM-Flickr
    11 Posts 3 Posters 10.4k Views 3 Watching
      bluecaka69
      I can’t seem to get the coding right when i add the code to config i get create a config i have ran through jshint and it states need semicolon on 18 and 19. there is one there so I’m not sure here is my code and of course i removed my id for security
          		module: 'MMM-Flickr',
          		position: 'bottom_center',
              		animationSpeed: 2500,
              		updateInterval: 10000
              		size: 'm' //Default is m, can be o=original, t=thumbnail, s= 		75x75, b=1024
      Note from admin: Please use Markdown on code snippets for easier reading!
        bluecaka69
        another thing but not sure here is ssh message from nam install does this look right i wasn’t sure which older to install so i did both
        pi@raspberrypi:~/MagicMirror/modules $ npm install
        npm WARN enoent ENOENT: no such file or directory, open '/home/pi/MagicMirror/modules/package.json'
        npm WARN enoent ENOENT: no such file or directory, open '/home/pi/MagicMirror/modules/node_modules/node_helper/package.json'
        npm WARN modules No description
        npm WARN modules No repository field.
        npm WARN modules No README data
        npm WARN modules No license field.
        pi@raspberrypi:~/MagicMirror/modules $ cd ..
        pi@raspberrypi:~/MagicMirror $ cd ..
        pi@raspberrypi:~ $ npm install
        npm WARN enoent ENOENT: no such file or directory, open '/home/pi/package.json'
        npm WARN pi No description
        npm WARN pi No repository field.
        npm WARN pi No README data
        npm WARN pi No license field.
        • Y Offline
          yawns Moderator @bluecaka69
          @bluecaka69
          Hi. There is a comma missing after the value 10000. Additionally there is a wrong ’ in front of your ID.
          The command npm install needs to be run inside the module folder ~/MagicMirror/modules/MMM-Flickr
          B 2 Replies Last reply Reply Quote 0
            bluecaka69 @yawns
            @yawns sorry about markdown i didn’t realize how to use it as Im pretty new
            I added the comma after 10000, not sure what you mean by wrong ’ in front of your ID. is there different ’ to use
            again thanks for you help i do appreciate it
            SO i installed npm install here and it ran properly
            pi@raspberrypi:~/MagicMirror/modules/MMM-Flickr $ npm install
            Magic-Mirror-Module-Flickr@1.0.0 /home/pi/MagicMirror/modules/MMM-Flickr```
              bluecaka69 @yawns
              @yawns thank you I got it it… must be something to do with textedit on mac when i put it the ’ it changes it from the code
              • Y Offline
                yawns Moderator
                Indeed, we see this a lot with Mac users.
                So, it is working for you now?
                  bluecaka69 @yawns
                  @yawns yes it is working great thanks again
                    bluecaka69 @yawns
                    @yawns dumb ? prolly. i am getting notice to update the module, is there a command to auto update??
                    • Y Offline
                      yawns Moderator
                      Open a Terminal:
                      cd ~/MagicMirror/modules/MMM-Flickr
                      git pull
                      npm install
                        bluecaka69
                        thank you i want sure if a general sudo apt-get update or sudo apt-get dist-upgrade
                        would work… thanks again I hope to one day be able to help others !!!
                        • F Offline
                          fox
                          Any approaches to make this possible on private albums?
