    HELP WITH MMM-Flickr
    11 Posts 3 Posters 9.9k Views 3 Watching
    • yawnsY Offline
      yawns Moderator @bluecaka69
      @bluecaka69
      Hi. There is a comma missing after the value 10000. Additionally there is a wrong ’ in front of your ID.
      The command npm install needs to be run inside the module folder ~/MagicMirror/modules/MMM-Flickr
        bluecaka69 @yawns
        @yawns sorry about markdown i didn’t realize how to use it as Im pretty new
        I added the comma after 10000, not sure what you mean by wrong ’ in front of your ID. is there different ’ to use
        again thanks for you help i do appreciate it
        SO i installed npm install here and it ran properly
        pi@raspberrypi:~/MagicMirror/modules/MMM-Flickr $ npm install
        Magic-Mirror-Module-Flickr@1.0.0 /home/pi/MagicMirror/modules/MMM-Flickr```
          bluecaka69 @yawns
          @yawns thank you I got it it… must be something to do with textedit on mac when i put it the ’ it changes it from the code
          • yawnsY Offline
            yawns Moderator
            Indeed, we see this a lot with Mac users.
            So, it is working for you now?
              bluecaka69 @yawns
              @yawns yes it is working great thanks again
                bluecaka69 @yawns
                @yawns dumb ? prolly. i am getting notice to update the module, is there a command to auto update??
                • yawnsY Offline
                  yawns Moderator
                  Open a Terminal:
                  cd ~/MagicMirror/modules/MMM-Flickr
                  git pull
                  npm install
                    bluecaka69
                    thank you i want sure if a general sudo apt-get update or sudo apt-get dist-upgrade
                    would work… thanks again I hope to one day be able to help others !!!
                    • foxF Offline
                      fox
                      Any approaches to make this possible on private albums?
                      Issues With MMM-WatchDog known?
                      https://forum.magicmirror.builders/post/29827
                      Useful for PIR-Sensor: https://forum.magicmirror.builders/post/21299
