    Trying to create a white background with black text to the clock module title block.
    15 Posts 2 Posters 8.7k Views 2 Watching
      sdetweil @synint
      @synint every module is different
      many styles are not inherited from its parent
      see this on how to use the developers window elements tab to find the classes and styles to use
      https://forum.magicmirror.builders/post/90135
        synint Project Sponsor @sdetweil
        Hi Sam,
        Thank you for the link and I am going to try and sort the style issue over the weekend.
        I will let you know how I get on.
        Cheers,
        John
          Hi Sam,
          It has taken me some time but I have now managed to get white boxes around the module text. The white box was created adding additional lines of code to custom.css file see code below. However I was unable to change the text colour in the white boxes so ended up changing the root section of the main.css file see code below. I know you said do not change the root code but could not find any other way of changing font colour.
          The one thing I would still like to do is remove image and date/time at the bottom right hand corner.
          Cheers,
          John
          Custom CSS Code
          /* Custom CSS Sample
           * Change color and fonts here.
           * Beware that properties cannot be unitless, so for example write '--gap-body: 0px;' instead of just '--gap-body: 0;'
          /* Uncomment and adjust accordingly if you want to import another font from the google-fonts-api: */
          /* @import url('https://fonts.googleapis.com/css2?family=Poppins:wght@100;300;400;700&display=swap'); */
          .clock {
             background-color:rgba(255,255,255,0.5);
             border-radius:8px;
             padding:8px;
          .clock .time{
           	color: black;
           .MMM-OpenmapWeather {
             border-radius:8px;
             padding:8px;
          .calendar {
             border-radius:8px;
             padding:8px;
          .newsfeed {
             border-radius:8px;
             padding:8px;
          .newsfeed .module-content{
             color: black;
          main.css file code
          :root {
            --color-text: #OOOOOO;
            --color-text-dimmed: #OOOOOO;
            --color-text-bright: #OOOOOO;
            --color-background: #000;
            --font-primary: "Roboto Condensed";
            --font-secondary: "Roboto";
            --font-size: 20px;
            --font-size-xsmall: 0.75rem;
            --font-size-small: 1rem;
            --font-size-medium: 1.5rem;
            --font-size-large: 3.25rem;
            --font-size-xlarge: 3.75rem;
            --gap-body-top: 60px;
            --gap-body-right: 60px;
            --gap-body-bottom: 60px;
            --gap-body-left: 60px;
            --gap-modules: 30px;
          ![0_1715368462168_20240510_200104-01.jpeg](Uploading 34%)
          S S 2 Replies Last reply Reply Quote 0
            synint Project Sponsor @synint
            Did not attach image on past post.
              sdetweil @synint
              @synint said in Trying to create a white background with black text to the clock module title block.:
              just copy that root section to custom.css
              then modify.
              again the developers window should make quick work of finding the right selector and style setting
