    Set 1280 x 720 resolution RPi Bookworm
    9 Posts 2 Posters 2.4k Views 2 Watching
    • F Offline
      frits.erasmus
      I have an old Sinoteq TV measuring 5780mm x 3250mm screen
      The closest resolution I get in the options is 1024 x 728. This causes images to show stretched
      I am running MagicMirror on it showing images
      How can I set the resolution to 1280 x 720?
      VERSION_ID=“12”
      VERSION=“12 (bookworm)”
      I tried editing the “/boot/firmware/cmdline.txt” file and added
      “video=HDMI-A-1:1280x720 vc4.force_hotplug=1” in that file.
      When the RPi starts up the TV echoes res = 1280X720 and the splash screen perspective is correct.
      As the Magic Mirror starts the same popup from the TV appears with Res = 1024x768 and when my image shows on screen, they are stretched (I am also viewing the screen with VNC and that perspective is correct)
      Is there a place in MM2 where I can set the resolution to 1280x720?
      Thanking any pointers in advance
      Frits
        sdetweil @frits.erasmus
        @frits-erasmus you can try adding
        electronOptions:{ width:1280, height:720},
        in config.js, before the line
        • F Offline
          frits.erasmus @sdetweil
          Thanks sdetwell, but that did not do the trick.
          Just want to make sure this is what you suggested I do?
          BTW: I have the TV vertical so I tried w1280 h720 and w720h1280 and neither made any difference
            @frits-erasmus ok, you didn’t say vertical
            let try this. electron might have saved something
            stop MagicMirror
            cd ~
            rm -rf  .config/Electron
            edit typo note dot in front of config
            then start MagicMirror again w config set to
            height:1280, width :720
            • F Offline
              frits.erasmus
              @sdetweil said in Set 1280 x 720 resolution RPi Bookworm:
              Sorry sdetweil ,
              That did not make any difference.
                @frits-erasmus bummer that all I’ve got for potential solutions
                I found this
                so lookup the wlr-randr command
                man wlr-randr
                or
                wlr-randr --help
                and I guess you would set it in the script that launches MagicMirror
                • F Offline
                  frits.erasmus
                  Thank you so much.
                  I will try that tomm,
                  Thanks for your feers anyway.
                  • F Offline
                    frits.erasmus
                    Am am giving up!!!
                    I am just going to buy a screen that conforms to the Raspbian software
                    Thanks for all the help
                    • F Offline
                      frits.erasmus
                      Thanks for trying to help me, but I have given up now.
                      I will just buy a monitor that conforms with standard RPI Raspbian OS
