    Date display for Calendar entries to be DD MM YYYY hh:mm - currently is "In 3 days"/"In 15 hours"
    12 Posts 2 Posters 3.8k Views 2 Watching
    • F Offline
      frits.erasmus
      I would like to show the date and time of an event in the format
      DD MM YYYY hh:mm
      I have tried the options in
      link text
      I just cannot get it right.
      Any help will be appreciated
      Frits
        sdetweil @frits.erasmus
        @frits-erasmus this is because you have timeFormat:“relative” (relative to today)
        you need timeFormat:“absolute”
        then the dateFormat: string will be used
        from the doc
        timeFormat	Display event times as absolute dates, or relative time, or using absolute date headers with times for each event next to it
        Possible values: absolute or relative or dateheaders
        Default value: relative  <-------
        • F Offline
          frits.erasmus @sdetweil
          @sdetweil Hi Sam,
          I must be doing something wrong and I cannot figure out how to resolve this.
          Below my code and screenshot of results
                                  header: "Daphne school program",
                                          maximumEntries: 15,
                                          maximumNumberOfDays: 5,
                                          maxTitleLength: 65,
                                          fade: false,
                                          colored: true,
                                          wrapEvents: true,
                                          format: "absolute",
                                          dateFormat: "Do MMMM hh:mm",
                                                          symbol: "calendar   ",
                                                          color: "#B4B4B4",
                                                          url:
          Could you please kindly help with some pointers?
          Also I am studying the following to do the right thing, but it appears you quoted from another source - Do you mind providing that for me:
          MagicMirror² Documentation
          and
          String + Format
          Thank you in advance
          Frits
            @frits-erasmus said in Date display for Calendar entries to be DD MM YYYY hh:mm - currently is "In 3 days"/"In 15 hours":
            format: “absolute”,
            but it’s timeFormat
            yes, the calendar doc is here
            https://docs.magicmirror.builders/modules/calendar.html#using-the-module
            the upper/first part is settings for ALL calendars
            the lower/second part is settings for a particular calendar. { url:…}
            F 2 Replies Last reply Reply Quote 0
            • F Offline
              Thank you Sam for that but I still do not get it to do what I want.
              I might be too thick.
              To make sure I understand you correct?
              White = upper part
              Yellow = lower part
              I have now tried the : format: “absolute” setting in the second part and as I understand in the manual set the date and time to show 15 May 14:25 .
              Just to make sure I also commented out the two format and dateFormat lines in the upper part
              What am I doing wrong then?
              • F Offline
                Okay, I also changed format to timeFormat
                  @frits-erasmus can u chat text me the config for the calendar module…
                  i did this
                          classes:"page1",
                          header: "US Holidays",
                            timeFormat: "absolute",
                            dateFormat:"MMM, HH:mm",
                            fullDayEventDateFormat: "MMM DD",
                            colored:true,
                            hidePrivate: true,
                            fetchInterval: 120000,
                            broadcastPastEvents: false,
                                fetchInterval: 604800000,
                                symbol: "calendar-check",
                                color: "pink",
                                url: "http://localhost:8090/modules/default/calendar/test_time_width.ics",
                                url: "https://www.google.com/calendar/ical/en.usa%23holiday@group.v.calendar.google.com/public/basic.ics",
                                color:"green"
                  and got this
                  note that dateFormat andfullDayEventDateFormat: “MMM DD” are different settings… (one has a time, the other doesn’t) (oops no time shown, see next post)
                  extra spaces cause problems too … symbol:"calendar ", is NOT correct
                    @frits-erasmus I also changed the test cal to have time and used other properties to force absolute
                            classes:"page1",
                              colored:true,
                              urgency: 0,
                              getRelative: 0,
                              hidePrivate: true,
                                  color: "pink",
                                  //url: "https://calendar.google.com/calendar/ical/brigidspina%40gmail.com/private-065de47caae525540e8b162d9af31b3f/basic.ics"
                                  color:"green"
                    • F Offline
                      My Code
                                                      dateFormat: "DD MMMM HH:mm",
                                                      colored: true,
                                                      maximumEntries: 15,
                                                      maxTitleLength: 65,
                                                      fade: false,
                                                      wrapEvents: true,
                                                      pastDaysCount: 1,
                                                      fetchInterval: 5 * 60 * 1000,
        color: "#37CBFF",
        url: "https://teneo.instructure.com/feeds/calendars/user_.ics"
        symbol: "fa-solid fa-pen-clip",
        color: "#F22E66",
        url: "https://calendar.google.com/calendar/ical//basic.ics"
                      Yes - I deleted a few characters from the URLs
                      MMM display
                      I double-checked everything and cannot find the error
                        @frits-erasmus notice the getRelative in mine
                        • F Offline
                          Thank you very much SAM - I really appreciate your help.
                          My understanding was that I needed to use one of the options:
                          the options timeFormat:“absolute”, urgency:0, getRelative:0,
                          Now, with hindsight, it makes sense that I should have all.
                          Thank you - you have taught me a lot. - now for me to tackle the next one.
                          My calendar:
                          I am going to try and fade the events that are in the past …Is that even possible? …Have to search
                            @frits-erasmusthe default calendar does not display events from the past, ever.
                            other add on modules that display a wall calendar view will do that.
