    Date display for Calendar entries to be DD MM YYYY hh:mm - currently is "In 3 days"/"In 15 hours"
    12 Posts 2 Posters 3.3k Views 2 Watching
    • F Offline
      frits.erasmus @sdetweil
      @sdetweil Hi Sam,
      I must be doing something wrong and I cannot figure out how to resolve this.
      Below my code and screenshot of results
                              header: "Daphne school program",
                                      maximumEntries: 15,
                                      maximumNumberOfDays: 5,
                                      maxTitleLength: 65,
                                      fade: false,
                                      colored: true,
                                      wrapEvents: true,
                                      format: "absolute",
                                      dateFormat: "Do MMMM hh:mm",
                                                      symbol: "calendar   ",
                                                      color: "#B4B4B4",
                                                      url:
      Could you please kindly help with some pointers?
      Also I am studying the following to do the right thing, but it appears you quoted from another source - Do you mind providing that for me:
      MagicMirror² Documentation
      and
      String + Format
      Thank you in advance
      Frits
        sdetweil @frits.erasmus
        @frits-erasmus said in Date display for Calendar entries to be DD MM YYYY hh:mm - currently is "In 3 days"/"In 15 hours":
        format: “absolute”,
        but it’s timeFormat
        yes, the calendar doc is here
        https://docs.magicmirror.builders/modules/calendar.html#using-the-module
        the upper/first part is settings for ALL calendars
        the lower/second part is settings for a particular calendar. { url:…}
        F 2 Replies Last reply Reply Quote 0
        • F Offline
          Thank you Sam for that but I still do not get it to do what I want.
          I might be too thick.
          To make sure I understand you correct?
          White = upper part
          Yellow = lower part
          I have now tried the : format: “absolute” setting in the second part and as I understand in the manual set the date and time to show 15 May 14:25 .
          Just to make sure I also commented out the two format and dateFormat lines in the upper part
          What am I doing wrong then?
          • F Offline
            Okay, I also changed format to timeFormat
              @frits-erasmus can u chat text me the config for the calendar module…
              i did this
                      classes:"page1",
                      header: "US Holidays",
                        timeFormat: "absolute",
                        dateFormat:"MMM, HH:mm",
                        fullDayEventDateFormat: "MMM DD",
                        colored:true,
                        hidePrivate: true,
                        fetchInterval: 120000,
                        broadcastPastEvents: false,
                            fetchInterval: 604800000,
                            symbol: "calendar-check",
                            color: "pink",
                            url: "http://localhost:8090/modules/default/calendar/test_time_width.ics",
                            url: "https://www.google.com/calendar/ical/en.usa%23holiday@group.v.calendar.google.com/public/basic.ics",
                            color:"green"
              and got this
              note that dateFormat andfullDayEventDateFormat: “MMM DD” are different settings… (one has a time, the other doesn’t) (oops no time shown, see next post)
              extra spaces cause problems too … symbol:"calendar ", is NOT correct
                @frits-erasmus I also changed the test cal to have time and used other properties to force absolute
                        classes:"page1",
                          colored:true,
                          urgency: 0,
                          getRelative: 0,
                          hidePrivate: true,
                              color: "pink",
                              //url: "https://calendar.google.com/calendar/ical/brigidspina%40gmail.com/private-065de47caae525540e8b162d9af31b3f/basic.ics"
                              color:"green"
                • F Offline
                  My Code
                                                  dateFormat: "DD MMMM HH:mm",
                                                  colored: true,
                                                  maximumEntries: 15,
                                                  maxTitleLength: 65,
                                                  fade: false,
                                                  wrapEvents: true,
                                                  pastDaysCount: 1,
                                                  fetchInterval: 5 * 60 * 1000,
        color: "#37CBFF",
        url: "https://teneo.instructure.com/feeds/calendars/user_.ics"
        symbol: "fa-solid fa-pen-clip",
        color: "#F22E66",
        url: "https://calendar.google.com/calendar/ical//basic.ics"
                  Yes - I deleted a few characters from the URLs
                  MMM display
                  I double-checked everything and cannot find the error
                    @frits-erasmus notice the getRelative in mine
                    • F Offline
                      Thank you very much SAM - I really appreciate your help.
                      My understanding was that I needed to use one of the options:
                      the options timeFormat:“absolute”, urgency:0, getRelative:0,
                      Now, with hindsight, it makes sense that I should have all.
                      Thank you - you have taught me a lot. - now for me to tackle the next one.
                      My calendar:
                      I am going to try and fade the events that are in the past …Is that even possible? …Have to search
                        @frits-erasmusthe default calendar does not display events from the past, ever.
                        other add on modules that display a wall calendar view will do that.
