    MMM-MyCommute not showing
    12 Posts 2 Posters 4.2k Views 2 Watching
      semihbakrac
      The MMM-MyCommute module is not working today. The RemoteControl module was installed, but I uninstalled it and reinstalled the same software from scratch. I installed the MyCommute module, but it does not appear on the screen.
      log:
        sdetweil @semihbakrac
        @semihbakrac that message says there is a copy of MagicMirror running already
        open a terminal window
        do
        pm2 status
        pm2 stop all
        pm2 restart xxx
        where xxx is the line number or name on the line fo the app you want to restart
          semihbakrac @sdetweil
          @sdetweil Why are there two? Also Mycommute does not appear on the screen
            @semihbakrac why are there two… use did the setup manually and created the mm one
            and then you used my script and replied yes to pm2, and I created one
            you can delete either
            pm2 delete xxx
            pm2 save
              @semihbakrac pm2 separates the errors and good output into two different files
              and displays them separately when using the pm2 logs command
              that is the good output
              I always recommend NOT using pm2 when changing config, adding a module
              pm2 stop all
              cd ~/MagicMirror
              npm start
              once you have it running like you want
              then pm2 start xxx
                @sdetweil Only mycommute doesn’t work. npm log is this
                semihbakrac@raspberrypi:~/MagicMirror $ npm start
                > magicmirror@2.27.0 start
                [2024-05-18 22:59:01.677] [LOG]   Starting MagicMirror: v2.27.0
                [2024-05-18 22:59:01.735] [LOG]   Loading config ...
                [2024-05-18 22:59:01.743] [LOG]   config template file not exists, no envsubst
                [2024-05-18 22:59:01.755] [LOG]   Loading module helpers ...
                [2024-05-18 22:59:01.758] [LOG]   No helper found for module: alert.
                [2024-05-18 22:59:02.424] [LOG]   Initializing new module helper ...
                [2024-05-18 22:59:02.425] [LOG]   Module helper loaded: updatenotification
                [2024-05-18 22:59:02.427] [LOG]   No helper found for module: clock.
                [2024-05-18 22:59:02.822] [LOG]   Initializing new module helper ...
                [2024-05-18 22:59:02.824] [LOG]   Module helper loaded: calendar
                [2024-05-18 22:59:02.825] [LOG]   No helper found for module: weather.
                [2024-05-18 22:59:03.625] [LOG]   Initializing new module helper ...
                [2024-05-18 22:59:03.626] [LOG]   Module helper loaded: MMM-MyCommute
                [2024-05-18 22:59:04.306] [LOG]   Initializing new module helper ...
                [2024-05-18 22:59:04.307] [LOG]   Module helper loaded: MMM-MyPrayerTimes
                [2024-05-18 22:59:04.308] [LOG]   All module helpers loaded.
                [2024-05-18 22:59:04.322] [LOG]   Starting server on port 8080 ...
                [2024-05-18 22:59:07.200] [LOG]   Server started ...
                [2024-05-18 22:59:07.203] [LOG]   Connecting socket for: updatenotification
                [2024-05-18 22:59:07.205] [LOG]   Starting module helper: updatenotification
                [2024-05-18 22:59:07.207] [LOG]   Connecting socket for: calendar
                [2024-05-18 22:59:07.209] [LOG]   Starting node helper for: calendar
                [2024-05-18 22:59:07.211] [LOG]   Connecting socket for: MMM-MyCommute
                [2024-05-18 22:59:07.213] [LOG]   ====================== Starting node_helper for module [MMM-MyCommute]
                [2024-05-18 22:59:07.215] [LOG]   Connecting socket for: MMM-MyPrayerTimes
                [2024-05-18 22:59:07.217] [LOG]   Starting node_helper for: MMM-MyPrayerTimes
                [2024-05-18 22:59:07.219] [LOG]   Sockets connected & modules started ...
                [2024-05-18 22:59:07.870] [LOG]   Launching application.
                [2024-05-18 22:59:10.593] [INFO]  System information:
                ### SYSTEM:   manufacturer: Raspberry Pi Foundation; model: Raspberry Pi 3 Model B Plus Rev 1.3; raspberry: [object Object]; virtual: false
                ### OS:       platform: linux; distro: Raspbian GNU/Linux; release: 12; arch: arm; kernel: 6.6.28+rpt-rpi-v7
                ### VERSIONS: electron: 29.1.6; used node: 20.9.0; installed node: 20.8.0; npm: 10.1.0; pm2: 5.3.1
                ### OTHER:    timeZone: Europe/Istanbul; ELECTRON_ENABLE_GPU: undefined
                [2024-05-18 22:59:13.101] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/semih342bakrac%40gmail.com/private-c2fb4dce86cf995b9f980010988f5bf9/basic.ics - Interval: 604800000
                [2024-05-18 22:59:13.397] [INFO]  updatenotification: Updater Class Loaded!
                [2024-05-18 22:59:13.399] [INFO]  updatenotification: Checking PM2 using...
                [2024-05-18 22:59:13.404] [INFO]  Checking git for module: MMM-MyCommute
                [2024-05-18 22:59:13.468] [INFO]  Checking git for module: MMM-MyPrayerTimes
                [2024-05-18 22:59:13.539] [INFO]  Checking git for module: MagicMirror
                [2024-05-18 22:59:13.592] [INFO]  updatenotification: [PM2] You are not using pm2
                [2024-05-18 22:59:13.811] [LOG]   200[object Object]
                [2024-05-18 22:59:14.196] [INFO]  Calendar-Fetcher: Broadcasting 0 events from https://calendar.google.com/calendar/ical/semih342bakrac%40gmail.com/private-c2fb4dce86cf995b9f980010988f5bf9/basic.ics.
                  @semihbakrac said in MMM-MyCommute not showing:
                  MMM-MyCommute
                  your config looks something like this… with proper start and end and the
                  google api key
                    module: 'MMM-MyCommute',
                    position: 'top_left',
                      apikey: 'API_KEY_FROM_GOOGLE',
                      origin: '65 Front St W, Toronto, ON M5J 1E6',
                      startTime: '00:00',
                      endTime: '23:59',
                      hideDays: [0,6],
                      destinations: [
                          destination: '14 Duncan St Toronto, ON M5H 3G8',
                          label: 'Air Canada Centre',
                          mode: 'walking',
                          color: '#82E5AA'
                          destination: '317 Dundas St W, Toronto, ON M5T 1G4',
                          label: 'Art Gallery of Ontario',
                          mode: 'transit'
                          destination: '55 Mill St, Toronto, ON M5A 3C4',
                          label: 'Distillery District',
                          mode: 'bicycling'
                          destination: '6301 Silver Dart Dr, Mississauga, ON L5P 1B2',
                          label: 'Pearson Airport',
                          avoid: 'tolls'
                    @sdetweil my config
                      			position: 'top_right',
                    			header: 'Tahmin Edilen Varis Suresi',
                        				apikey: 'myAPI',
                        				origin: 'Menderes, 381. Sk. 13-1, 34225 Esenler/Istanbul',
                        				startTime: '00:00',
                        				endTime: '23:59',
                        				hideDays: [0,6],
                        				destinations: [
                            				destination: 'Sekerpinar, Otomotiv Cd. No:2, 41435 CAYIROVA/Cayirova/Kocaeli',
                            				label: 'Araba',
                            				mode: 'driving',
                    					alternatives: true,
                            				label: 'Toplu Tasima',
                            				mode: 'transit'
                            				destination: 'Halicioglu, 34445 Beyoglu/Istanbul',
                            				label: 'Servis Kalkis Noktasi',
                            				mode: 'transit'
                      hideDays: [0,6],
                      so, you hid all the days??
                      I edited out everything but this module def
                        @sdetweil omg. My brain is not working. I’m sorry to keep you busy :((( . Thanks for support
                        • S semihbakrac has marked this topic as solved on
                        • S semihbakrac has marked this topic as unsolved on
                          @sdetweil I can only color the driving icon. I cannot color other icons. Bus,subway etc. The application acts as if the config file does not exist and only the warning screen appears. Do you know anything about this?
                            @semihbakrac sorry, know nothing about the internals…
