    Openweathermap api works for 2 of my modules but not for Hourly
    9 Posts 2 Posters 1.6k Views 2 Watching
    • H Offline
      hengy
              module: "weather",
              header: "Hourly",
                      type: 'hourly',
                      apiKey: "new api key",
                      units: "imperial",
                      maxEntries: 10,
                      fadePoint: 0.12,
      	    showPrecipationAmount: true,
      	    AnimationSpeed: 1000,
                      ignoreToday: true,
                      colored: true,
                      fade: false,
                      timeFormat: 12,
                      showFeelsLike: true,
                      lat: 40.7128,
                      lon: -74.0060,
      I’ve got a new api key, just replaced the old one. It was working fine. Any ideas why this might not be working?
        sdetweil @hengy
        @hengy hourly uses the /onecall endpoint, and I think the new apikey ONLY works with the v3.0 api on onecall
        SO,
        in config for hourly set
        apiVersion :'3.0'
        it defaults to 2.5 til next release
        • H Offline
          hengy @sdetweil
          I’ve added it here. No luck.
          module: "weather",
                  header: "Hourly",
                         type: 'hourly',
                           apiVersion :'3.0',
                          units: "imperial",
                          maxEntries: 10,
                          fadePoint: 0.12,
                          ignoreToday: true,
                          colored: true,
                          fade: false,
                          timeFormat: 12,
                          lat: 40.7128,
                          lon: -74.0060,
            sdetweil @hengy
            @hengy I took your config (edited and added the code block and start/end {} in your post)
            and my apikey
            on version 2.27
            and got this
            • H Offline
              hengy @sdetweil
              @sdetweil Maybe my mistake. I’m using the new ver 3 api. Should I be using the previous version I had running with no issues?
                sdetweil @hengy
                @hengy I don’t know. I am using my 3.0 apikey
                • H Offline
                  hengy @sdetweil
                  @sdetweil possible they changed the plan. I’m using free.
                    sdetweil @hengy
                    @hengy yes that doesnt provide hourly, says so right there.
                    that is the plan that is going away. 2.5
                    you must provide a credit card for 3.0 onecall
                    first 1000 calls per day are no charge
                    note: 3 module instances is 3 calls
                    so only 333/ day. only 4 calls per minute each module
                    • H Offline
                      hengy @sdetweil
                      Thanks for your help, will do.
