    Issues running MM in a 32 bits laptop and Debian 12
    3 Posts 2 Posters 426 Views 2 Watching
    • M
      Marcophy
      Hi!
      I’m trying to run MM in an old 32 bits laptop using Debian 12, but I´m having a lot of compatibility problems. I hope someone can help me!
      I couldn’t follow the “standard” installation process , so I followed these steps:
        1. Install node.js and npm using “sudo apt install nodejs npm -y” instead of the steps explained in https://github.com/nodesource/distributions
        1. Clone and install the MM from Github repository as explained in https://docs.magicmirror.builders/getting-started/installation.html
        1. After running MM, I got the error message “electron.js not found”, so I manually installed the version 4.2.12 using the command npm install electron@4.2.12 --force because this version is the last one with 32 bits support (I guess). It fixed the problem.
      Now, when I run MM I get the following error:
      A JavaScript error occurred in the main process
      Uncaught Exception:
      Error: Cannot find module 'node:fs'
          at Module._resolveFilename (internal/modules/cjs/loader.js:584:15)
          at Function.Module._resolveFilename (/home/mirror/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:43:12)
          at Function.Module._resolveFilename (/home/mirror/MagicMirror/node_modules/module-alias/index.js:49:29)
          at Function.Module._load (internal/modules/cjs/loader.js:510:25)
          at Module.require (internal/modules/cjs/loader.js:640:17)
          at require (internal/modules/cjs/helpers.js:20:18)
          at Object.<anonymous> (/home/mirror/MagicMirror/js/app.js:4:12)
          at Object.<anonymous> (/home/mirror/MagicMirror/js/app.js:367:3)
          at Module._compile (internal/modules/cjs/loader.js:693:30)
          at Object.Module._extensions..js (internal/modules/cjs/loader.js:704:10)
      Fontconfig warning: "/usr/share/fontconfig/conf.avail/05-reset-dirs-sample.conf", line 6: unknown element "reset-dirs"
      Any suggestions to fix this problem?
        sdetweil @Marcophy
        @Marcophy use my install script
        see
        that electron is very old and doesn’t support the es6 js language elements we are using
        in cases where electron doesn’t exist anymore (armv6l for sure)
        the install script sets up for MagicMirror server mode and launches the system browser over it.
        chromium by default but by using an env variable you can change to Firefox or midori or surf
        the install script sets up the proper versions of node and npm as well as handles other tweaks as necessary
          sdetweil @Marcophy
          @Marcophy or, you can try this yourself
          download the run-start.sh script into the MagicMirror folder,
          make it executable
          change the package.json start script to launch run-start.sh
          “start”: “./run-start.sh”,
          then make sure you have chromium or another browser and add the
          env variable as documented in my script readme(shown as web page for repo on github)
          then npm start will launch run-start,
          which will launch MagicMirror server mode
          and once it’s up, it will launch the browser you select
