    node generate_token_v2 error
    16 Posts 5 Posters 3.8k Views 5 Watching
    • C Offline
      Crimson0087
      Hello,
      I am a computer coding novice…as in I do not know what ANY of this means and am just following tutorials. I am currently at the step on my raspberry pi where I have added the credentials.json to the MMM-GooglePhotos file and have typed
      node generate_token_v2.js
      This is the error I get
      (node:4639) [DEP0040] DeprecationWarning: The punycode module is deprecated. Please use a userland alternative instead.
      (Use node --trace-deprecation ... to show where the warning was created)
      can anyone tell me what I am doing wrong?
      S A 2 Replies Last reply Reply Quote 0
        atagg00g @Crimson0087
        @Crimson0087 I had a similar issue after mine decided to break the API connection after a week. I have posted on the repo issue pages what I was able to do to fix your exact problem. Go figure you were attempting at the exact same time I was troubleshooting it. https://github.com/hermanho/MMM-GooglePhotos/issues/191
          sdetweil @Crimson0087
          @Crimson0087 nothing you can do anything about.
          • C Offline
            Crimson0087 @sdetweil
            Does that mean I cannot use the Google photos with magic mirror?
              @Crimson0087 no, just ignore that message
              • C Offline
                That’s a hard stop…it doesn’t perform the action. According to tutorial when I type node generate_tokenv2 it should open a new window for me to log in to Google account and that doesn’t happen… nothing happens
                  @Crimson0087 you ARE doing this ON the system console of the MagicMirror system, right… not over ssh or (maybe vnc, don’t use)
                  • C Offline
                    @sdetweil yes
                      @Crimson0087 and you did put the downloaded creendtial json file in this folder with the name ‘credentials.json’
                      • C Offline
                        Yes I did.
                          @Crimson0087 ok, that has exhausted my experience here
                          • BKeyportB Offline
                            @sdetweil Google did change their login experience anyway, so if the module’s not being maintained, it’s a hard stop, likely.
                              sdetweil @BKeyport
                              @BKeyport this is GoogleAssistant…
                              @bugsounet any help?
                              bugsounetB 1 Reply Last reply Reply Quote 0
                              • bugsounetB Offline
                                bugsounet Banned @sdetweil
                                I haven’t noticed any issues creating tokens.
                                I don’t use the same method (mine is web app) and I use one credentials file (MMM-GoogleAssuistant credentials) for generate any token (Google Photo, Youtube, …)
                                This is my Terminal return:
                                bugsounet@PC-Bugsounet:~/MagicMirror/modules/EXT-GooglePhotos$ npm run token
                                > EXT-GooglePhotos@1.4.4 token
                                > installer/token.sh
                                Welcome to EXT-GooglePhotos Token generator!
                                Do you want to install/reinstall EXT-GooglePhotos token? [Y/n]
                                Your choice: y
                                [GPHOTOS] Check credentials.json...
                                [GPHOTOS] credentials.json found in /home/bugsounet/MagicMirror/modules/MMM-GoogleAssistant/credentials.json
                                [GPHOTOS] config: {
                                  CREDENTIALS: '/home/bugsounet/MagicMirror/modules/MMM-GoogleAssistant/credentials.json',
                                  TOKEN: '/home/bugsounet/MagicMirror/modules/EXT-GooglePhotos/tokenGP.json'
                                (node:3839) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
                                (Use `node --trace-deprecation ...` to show where the warning was created)
                                [GPHOTOS:AUTH] Opening OAuth URL.
                                https://accounts.google.com/o/oauth2/v2/auth?access_type=offline&scope=https%3A%2F%2Fwww.googleapis.com%2Fauth%2Fphotoslibrary%20https%3A%2F%2Fwww.googleapis.com%2Fauth%2Fphotoslibrary.sharing&prompt=consent&response_type=code&client_id=XXXX&redirect_uri=https%3A%2F%2Fgoogleassistant.bugsounet.fr
                                Return here with your code.
                                > Paste your code: 4/0ATx3LY7fxmvgcDJ2qZrx...........
                                [GPHOTOS:AUTH] Token is refreshed.
                                [GPHOTOS] TokenGP is generated.
                                So I think author have to review his token generator
                                @bugsounet
                                • BKeyportB Offline
                                  BKeyport Module Developer @bugsounet
                                  @bugsounet so, silly question as I don’t use google for anything but an old email address - Would a token generated in your app work in the other app?
                                    bugsounet Banned @BKeyport
                                    @BKeyport : the structure of the token is not the same
                                    The "E" in "Javascript" stands for "Easy" is not always true ;/
