    node generate_token_v2 error
    16 Posts 5 Posters 2.8k Views 5 Watching
    • BKeyportB Offline
      @sdetweil Google did change their login experience anyway, so if the module’s not being maintained, it’s a hard stop, likely.
        sdetweil @BKeyport
        @BKeyport this is GoogleAssistant…
        @bugsounet any help?
        bugsounetB 1 Reply Last reply Reply Quote 0
        • bugsounetB Offline
          bugsounet Banned @sdetweil
          I haven’t noticed any issues creating tokens.
          I don’t use the same method (mine is web app) and I use one credentials file (MMM-GoogleAssuistant credentials) for generate any token (Google Photo, Youtube, …)
          This is my Terminal return:
          bugsounet@PC-Bugsounet:~/MagicMirror/modules/EXT-GooglePhotos$ npm run token
          > EXT-GooglePhotos@1.4.4 token
          > installer/token.sh
          Welcome to EXT-GooglePhotos Token generator!
          Do you want to install/reinstall EXT-GooglePhotos token? [Y/n]
          Your choice: y
          [GPHOTOS] Check credentials.json...
          [GPHOTOS] credentials.json found in /home/bugsounet/MagicMirror/modules/MMM-GoogleAssistant/credentials.json
          [GPHOTOS] config: {
            CREDENTIALS: '/home/bugsounet/MagicMirror/modules/MMM-GoogleAssistant/credentials.json',
            TOKEN: '/home/bugsounet/MagicMirror/modules/EXT-GooglePhotos/tokenGP.json'
          (node:3839) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
          (Use `node --trace-deprecation ...` to show where the warning was created)
          [GPHOTOS:AUTH] Opening OAuth URL.
          https://accounts.google.com/o/oauth2/v2/auth?access_type=offline&scope=https%3A%2F%2Fwww.googleapis.com%2Fauth%2Fphotoslibrary%20https%3A%2F%2Fwww.googleapis.com%2Fauth%2Fphotoslibrary.sharing&prompt=consent&response_type=code&client_id=XXXX&redirect_uri=https%3A%2F%2Fgoogleassistant.bugsounet.fr
          Return here with your code.
          > Paste your code: 4/0ATx3LY7fxmvgcDJ2qZrx...........
          [GPHOTOS:AUTH] Token is refreshed.
          [GPHOTOS] TokenGP is generated.
          So I think author have to review his token generator
          @bugsounet
          • BKeyportB Offline
            BKeyport Module Developer @bugsounet
            @bugsounet so, silly question as I don’t use google for anything but an old email address - Would a token generated in your app work in the other app?
              bugsounet Banned @BKeyport
              @BKeyport : the structure of the token is not the same
              The "E" in "Javascript" stands for "Easy" is not always true ;/
                atagg00g @Crimson0087
                @Crimson0087 I had a similar issue after mine decided to break the API connection after a week. I have posted on the repo issue pages what I was able to do to fix your exact problem. Go figure you were attempting at the exact same time I was troubleshooting it. https://github.com/hermanho/MMM-GooglePhotos/issues/191
