    node generate_token_v2 error
    16 Posts 5 Posters 2.9k Views 5 Watching
      sdetweil @Crimson0087
      @Crimson0087 ok, that has exhausted my experience here
      • BKeyportB Offline
        @sdetweil Google did change their login experience anyway, so if the module’s not being maintained, it’s a hard stop, likely.
          sdetweil @BKeyport
          @BKeyport this is GoogleAssistant…
          @bugsounet any help?
          bugsounetB 1 Reply Last reply Reply Quote 0
          • bugsounetB Offline
            bugsounet Banned @sdetweil
            I haven’t noticed any issues creating tokens.
            I don’t use the same method (mine is web app) and I use one credentials file (MMM-GoogleAssuistant credentials) for generate any token (Google Photo, Youtube, …)
            This is my Terminal return:
            bugsounet@PC-Bugsounet:~/MagicMirror/modules/EXT-GooglePhotos$ npm run token
            > EXT-GooglePhotos@1.4.4 token
            > installer/token.sh
            Welcome to EXT-GooglePhotos Token generator!
            Do you want to install/reinstall EXT-GooglePhotos token? [Y/n]
            Your choice: y
            [GPHOTOS] Check credentials.json...
            [GPHOTOS] credentials.json found in /home/bugsounet/MagicMirror/modules/MMM-GoogleAssistant/credentials.json
            [GPHOTOS] config: {
              CREDENTIALS: '/home/bugsounet/MagicMirror/modules/MMM-GoogleAssistant/credentials.json',
              TOKEN: '/home/bugsounet/MagicMirror/modules/EXT-GooglePhotos/tokenGP.json'
            (node:3839) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
            (Use `node --trace-deprecation ...` to show where the warning was created)
            [GPHOTOS:AUTH] Opening OAuth URL.
            https://accounts.google.com/o/oauth2/v2/auth?access_type=offline&scope=https%3A%2F%2Fwww.googleapis.com%2Fauth%2Fphotoslibrary%20https%3A%2F%2Fwww.googleapis.com%2Fauth%2Fphotoslibrary.sharing&prompt=consent&response_type=code&client_id=XXXX&redirect_uri=https%3A%2F%2Fgoogleassistant.bugsounet.fr
            Return here with your code.
            > Paste your code: 4/0ATx3LY7fxmvgcDJ2qZrx...........
            [GPHOTOS:AUTH] Token is refreshed.
            [GPHOTOS] TokenGP is generated.
            So I think author have to review his token generator
            @bugsounet
            • BKeyportB Offline
              BKeyport Module Developer @bugsounet
              @bugsounet so, silly question as I don’t use google for anything but an old email address - Would a token generated in your app work in the other app?
                bugsounet Banned @BKeyport
                @BKeyport : the structure of the token is not the same
                The "E" in "Javascript" stands for "Easy" is not always true ;/
                  atagg00g @Crimson0087
                  @Crimson0087 I had a similar issue after mine decided to break the API connection after a week. I have posted on the repo issue pages what I was able to do to fix your exact problem. Go figure you were attempting at the exact same time I was troubleshooting it. https://github.com/hermanho/MMM-GooglePhotos/issues/191
