    Problems with "MMM-MyBMW"
    7 Posts 2 Posters 1.0k Views 2 Watching
    • V Offline
      Vauxdvihl
      Hi all,
      i am trying to get “MMM-MYBMW” to work.
      But i think, i forgot to install some additional modules
      The error message looks like
      [2024-06-14 15:46:46.534] [ERROR] bimmer_connected error: Traceback (most recent call last):
        File ".../MagicMirror/modules/MMM-MyBMW/getMyBMWData.py", line 6, in <module>
          from bimmer_connected.account import MyBMWAccount
      ModuleNotFoundError: No module named 'bimmer_connected'
      Can please somebody help me?
      Thx a lot
        sdetweil @Vauxdvihl
        @Vauxdvihl did you see this in the module doc?
        Requirements
        A working python 3 distribution with pip is required before the installation.
        did you do
        npm install
        per the modile instructions?
        S V 2 Replies Last reply Reply Quote 0
          @sdetweil I don’t know how I checked solution and don’t know how to uncheck it
          • V Offline
            Vauxdvihl @sdetweil
            Yes i did
            But i did not find anything ni the docs with regards to python
            I installed it again
            warni@raspberrypi:~/MagicMirror/modules/MMM-MyBMW $ npm install
            > MMM-MyBMW@1.0.0 preinstall
            > echo 'Installing Python Dependencies...' && pip install -r requirements.txt --no-warn-script-location
            error: externally-managed-environment
            × This environment is externally managed
            ╰─> To install Python packages system-wide, try apt install
                python3-xyz, where xyz is the package you are trying to
                install.
                If you wish to install a non-Debian-packaged Python package,
                create a virtual environment using python3 -m venv path/to/venv.
                Then use path/to/venv/bin/python and path/to/venv/bin/pip. Make
                sure you have python3-full installed.
                For more information visit http://rptl.io/venv
            note: If you believe this is a mistake, please contact your Python installation or OS distribution provider. You can override this, at the risk of breaking your Python installation or OS, by passing --break-system-packages.
            hint: See PEP 668 for the detailed specification.
            npm ERR! code 1
            npm ERR! path /.../MagicMirror/modules/MMM-MyBMW
            npm ERR! command failed
            npm ERR! command sh -c echo 'Installing Python Dependencies...' && pip install -r requirements.txt --no-warn-script-location
            npm ERR!     /.../.npm/_logs/2024-06-14T14_33_26_887Z-debug-0.log
            I think the installation did not work
              sdetweil @Vauxdvihl
              @Vauxdvihl yes, you do mot have python setup like the author assumes
              from the doc
              and he doesn’t say but requires that you be running under some python virtual environment
              • V Offline
                Vauxdvihl
                ...@raspberrypi:~ $ python --version
                Python 3.11.2
                Python is available
                But the installation errors (npm install) remains the same
                  sdetweil @Vauxdvihl
                  @Vauxdvihl yes, the messages say about apt install or venv
                  I think the author needs to fix this. please open an issue on the module github page to engage the author.
                  • karsten13K karsten13 has marked this topic as unsolved on
