    problem with module MMM-backgroundslideshow
    5 Posts 3 Posters 974 Views 3 Watching
    • B
      benoit73
      hello,
      i have a problem with module MMM-backgroundslideshow. It work but i have no image show on screen.
      I have 6 images in Downloads file
          module: 'MMM-BackgroundSlideshow',
          position: 'fullscreen_below',
            recursiveSubDirectories: false,
            imagePaths: ['~/Downloads'],
            gradientDirection: "radial",
            radialGradient: [
              "rgba(0,0,0,0,0.4) 0%",
              "rgba(0,0,0,0,0.4) 25%",
              "rgba(0,0,0,0,0.4) 75%",
              "rgba(0,0,0,0,0.4) 100%"
              horizontalGradient: [
       "rgba(0,0,0,0,0.3) 0%",
       "rgba(0,0,0,0,0.1) 25%",
       "rgba(0,0,0,0,0) 50%",
       "rgba(0,0,0,0,0.1) 75%",
       "rgba(0,0,0,0,0.3) 100%"
      gradient: [
       "rgba(0,0,0,0,0) 0%",
       "rgba(0,0,0,0,0) 100%"
      transitions: ['opacity'],
      slideshowSpeed: "600000",
            randomizeImageOrder: true,
      backgroundSize: "cover",
      backgroundAnimationEnabled: false,
      transitionImages: true,
      transitionSpeed: "5s",
      showProgressBar: false,
      showImageInfo: true,
      imageInfo: "date,name",
      imageInfoLocation: "bottomRight",
      imageInfoNoFileExt: true
        sdetweil @benoit73
        @benoit73 I do not think the tidle char works outside the shell
        ~/Downloads
        change to the full.path
        • C
          caw
          hi together,
          do you have any solution right now?
          i replaced the folder with the one i want to use but receiving following issue. maybe someone can help?
          2024/09/24 11:04:27 stderr at Timeout._onTimeout (/opt/magic_mirror/modules/MMM-BackgroundSlideshow/node_helper.js:315:14)
          2024/09/24 11:04:27 stderr at Class.gatherImageList (/opt/magic_mirror/modules/MMM-BackgroundSlideshow/node_helper.js:119:12)
          2024/09/24 11:04:27 stderr at Class.getFiles (/opt/magic_mirror/modules/MMM-BackgroundSlideshow/node_helper.js:270:47)
          2024/09/24 11:04:27 stdout [2024-09-24 11:04:27.420] [INFO] BACKGROUNDSLIDESHOW: Reading directory “/volume1/photo/2024_Tansania/public” for images.
          hopefully to get it done :)
          S 2 Replies Last reply
            sdetweil @caw
            @caw you are using docker on synology
            so you have to be careful about permissions
            the docker container is running as user 1000
            but you probably created the folder with your synology userid,
            so you need to grant permission
            for other to read/write the folder and/or pictures
            sudo chmod -R xx6 folder_name
            xx means find out current and use those for user and group
            ls -laF
            will list the permissions, user and group for this directory and files
              sdetweil @caw
              @caw did you get this working?
