    v2.28.0
    Scheduled Pinned Locked Moved MagicMirror
    1 Posts 1 Posters 2.3k Views 1 Watching
    • karsten13K
      karsten13
      https://github.com/MagicMirrorOrg/MagicMirror/releases/tag/v2.28.0
      [2.28.0] - 2024-07-01
      Thanks to: @btoconnor, @bugsounet, @JasonStieber, @khassel, @kleinmantara and @WallysWellies.
      ⚠️ This release needs nodejs version >= v20.9.0
      Added
      • [calendar] Added config option “showEndsOnlyWithDuration” for default calendar
      • [compliments] Added specialDayUnique config option, defaults to false (#3465)
      • [weather] Provider weathergov: Use precipitationLast3Hours if precipitationLastHour is null (#3124)
      Removed
      • [tests] delete node v18 support (#3462)
      Updated
      • [core] Update dependencies including electron to v31
      • [core] use node >= v20 (#3462)
      • [core] Update config.js.sample to use openmeteo as weather provider which needs no api key
      • [tests] Use latest@version of node for automated-tests.yaml (#3483)
      • [updatenotification] Avoid using pm2 when running in docker container
      Fixed
      • [core] Fixed crash possibility if module: <name> is not defined and on postion: <positon> mistake (#3445)
      • [weather] Fixed precipitationProbability in forecast for provider openmeteo (#3446)
      • [weather] Fixed type=daily for provider openmeteo having no data when running after 23:00 (#3449)
      • [weather] Fixed type=daily for provider openmeteo showing nightly icons in forecast when current time is “nightly” (#3458)
      • [weather] Fixed forecast and hourly weather for provider openmeteo to use real temperatures, not apparent temperatures (#3466)
      • [tests] Fixed e2e tests running in docker container which needs address: "0.0.0.0" (#3479)
      • karsten13K karsten13 locked this topic on
