    Tado is no longer displayed after update 2.28
    12 Posts 2 Posters 1.4k Views 2 Watching
      JoeFranz @sdetweil
      > magicmirror@2.28.0 start
      [2024-07-01 12:56:47.307] [LOG]   Starting MagicMirror: v2.28.0
      [2024-07-01 12:56:47.381] [LOG]   Loading config ...
      [2024-07-01 12:56:47.387] [LOG]   config template file not exists, no envsubst
      [2024-07-01 12:56:51.040] [LOG]   ====================== Starting node_helper for module [MMM-OpenWeatherMapForecast]
      [2024-07-01 12:56:51.056] [LOG]   [Tools] MMM-Tools Version: 2.1.7
      [2024-07-01 12:56:51.066] [LOG]   Starting node_helper for module: MMM-PhilipsHue
      [2602:0701/125724.577098:ERROR:atom_cache.cc(229)] Add WM_CHANGE_STATE to kAtomsToCache
        sdetweil @JoeFranz
        @JoeFranz well that’s incredibly short
        J 2 Replies Last reply Reply Quote 0
          JoeFranz @sdetweil
          @sdetweil But everything else works, except Tado
            JoeFranz @sdetweil
            @sdetweil I have now reinstalled Tado and am getting these messages
            npm warn deprecated inflight@1.0.6: This module is not supported, and leaks memory. Do not use it. Check out lru-cache if you want a good and tested way to coalesce async requests by a key value, which is much more comprehensive and powerful.
            npm warn deprecated glob@7.2.0: Glob versions prior to v9 are no longer supported
            added 100 packages, and audited 101 packages in 33s
            22 packages are looking for funding
              run `npm fund` for details
            2 moderate severity vulnerabilities
            To address all issues (including breaking changes), run:
              npm audit fix --force
            Run `npm audit` for details.
              sdetweil @JoeFranz
              @JoeFranz noise, ignore
              does it work now?
                JoeFranz @sdetweil
                @sdetweil No, it is not displayed
                  JoeFranz @sdetweil
                  There was probably an error in the config regarding the position of the modules. Two modules had “top_right” and Tado had “right”. With “bottom_right” for Tado it is now displayed again. Strange that it worked like this before the update…
                  • J JoeFranz has marked this topic as solved on
                    sdetweil @JoeFranz
                    @JoeFranz ah, there should have been an error listed, as we added position checking to this release. used to cause a crash
