Tado is no longer displayed after update 2.28
since the update to 2.28, MMM-Tado no longer works, nothing is displayed. There are no errors in the logs.
Can anyone help? -
@JoeFranz let’s look this way
pm2 stop all
npm start -
@sdetweil The same, Tado is not displayed :-(
@JoeFranz but what are the messages from npm start
pi@raspberrypi:~/MagicMirror $ npm start > magicmirror@2.28.0 start > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js [2024-07-01 12:56:47.307] [LOG] Starting MagicMirror: v2.28.0 [2024-07-01 12:56:47.381] [LOG] Loading config ... [2024-07-01 12:56:47.387] [LOG] config template file not exists, no envsubst [2024-07-01 12:56:51.040] [LOG] ====================== Starting node_helper for module [MMM-OpenWeatherMapForecast] [2024-07-01 12:56:51.056] [LOG] [Tools] MMM-Tools Version: 2.1.7 [2024-07-01 12:56:51.066] [LOG] Starting node_helper for module: MMM-PhilipsHue [2602:0701/125724.577098:ERROR:atom_cache.cc(229)] Add WM_CHANGE_STATE to kAtomsToCache -
@JoeFranz well that’s incredibly short
@sdetweil But everything else works, except Tado
@sdetweil I have now reinstalled Tado and am getting these messages
npm warn deprecated inflight@1.0.6: This module is not supported, and leaks memory. Do not use it. Check out lru-cache if you want a good and tested way to coalesce async requests by a key value, which is much more comprehensive and powerful. npm warn deprecated glob@7.2.0: Glob versions prior to v9 are no longer supported added 100 packages, and audited 101 packages in 33s 22 packages are looking for funding run `npm fund` for details 2 moderate severity vulnerabilities To address all issues (including breaking changes), run: npm audit fix --force Run `npm audit` for details. -
@JoeFranz noise, ignore
does it work now? -
@sdetweil No, it is not displayed
There was probably an error in the config regarding the position of the modules. Two modules had “top_right” and Tado had “right”. With “bottom_right” for Tado it is now displayed again. Strange that it worked like this before the update… -
J JoeFranz has marked this topic as solved on
@JoeFranz ah, there should have been an error listed, as we added position checking to this release. used to cause a crash
