    Update Problem
    5 Posts 3 Posters 2.5k Views 3 Watching
    • L Offline
      Lockslay
      Hello everyone,
      I wanted to update my Magic Mirror via the console and I get this error message, can someone please help me?
      git pull && npm run install-mm
      Already up to date.
      magicmirror@2.28.0 install-mm
      npm install --no-audit --no-fund --no-update-notifier --only=prod --omit=dev
      npm error code EBADENGINE
      npm error engine Unsupported engine
      npm error engine Not compatible with your version of node/npm: @eslint/eslintrc@3.1.0
      npm error notsup Not compatible with your version of node/npm: @eslint/eslintrc@3.1.0
      npm error notsup Required: {“node”:“^18.18.0 || ^20.9.0 || >=21.1.0”}
      npm error notsup Actual: {“npm”:“10.8.1”,“node”:“v20.8.0”}
      npm error A complete log of this run can be found in: /root/.npm/_logs/2024-07-01T03_47_31_928Z-debug-0.log
      less /root/.npm/_logs/2024-07-01T03_47_31_928Z-debug-0.log
      0 verbose cli /usr/local/bin/node /usr/local/bin/npm
      1 info using npm@10.8.1
      2 info using node@v20.8.0
      3 silly config load:file:/usr/local/lib/node_modules/npm/npmrc
      4 warn config only Use --omit=dev to omit dev dependencies from the install.
      5 silly config load:file:/home/stefan/MagicMirror/.npmrc
      6 silly config load:file:/root/.npmrc
      7 silly config load:file:/usr/local/etc/npmrc
      8 verbose title npm install
      9 verbose argv “install” “–no-audit” “–no-fund” “–no-update-notifier” “–only” “prod” “–omit” “dev”
      10 verbose logfile logs-max:10 dir:/root/.npm/_logs/2024-07-01T03_47_31_928Z-
      11 verbose logfile /root/.npm/_logs/2024-07-01T03_47_31_928Z-debug-0.log
      12 silly packumentCache heap:247726080 maxSize:61931520 maxEntrySize:30965760
      13 silly logfile start cleaning logs, removing 1 files
      14 silly logfile done cleaning log files
      15 silly idealTree buildDeps
      16 verbose stack Error: Unsupported engine
      16 verbose stack at checkEngine (/usr/local/lib/node_modules/npm/node_modules/npm-install-checks/lib/index.js:14:25)
      16 verbose stack at #checkEngineAndPlatform (/usr/local/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/build-ideal-tree.js:198:11)
      16 verbose stack at Arborist.buildIdealTree (/usr/local/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/build-ideal-tree.js:184:41)
      16 verbose stack at async Promise.all (index 1)
      16 verbose stack at async Arborist.reify (/usr/local/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/reify.js:131:5)
      16 verbose stack at async Install.exec (/usr/local/lib/node_modules/npm/lib/commands/install.js:150:5)
      16 verbose stack at async Npm.exec (/usr/local/lib/node_modules/npm/lib/npm.js:207:9)
      16 verbose stack at async module.exports (/usr/local/lib/node_modules/npm/lib/cli/entry.js:74:5)
      17 verbose pkgid @eslint/eslintrc@3.1.0
      18 error code EBADENGINE
      19 error engine Unsupported engine
      20 error engine Not compatible with your version of node/npm: @eslint/eslintrc@3.1.0
      21 error notsup Not compatible with your version of node/npm: @eslint/eslintrc@3.1.0
      21 error notsup Required: {“node”:“^18.18.0 || ^20.9.0 || >=21.1.0”}
      21 error notsup Actual: {“npm”:“10.8.1”,“node”:“v20.8.0”}
      22 silly unfinished npm timer reify 1719805654317
      23 silly unfinished npm timer reify:loadTrees 1719805654372
      24 verbose cwd /home/stefan/MagicMirror
      25 verbose os Linux 6.6.31+rpt-rpi-v7
      26 verbose node v20.8.0
        sdetweil @Lockslay
        @Lockslay yes, you need to uprade nodejs to at least version 20.10
        I think 20.15 is current
        • el97E Offline
          el97
          I’m facing the same issue here even though I have the latest version of node.js and npm installed.
          npm error engine Not compatible with your version of node/npm: magicmirror@2.28.0
          npm error notsup Not compatible with your version of node/npm: magicmirror@2.28.0
          npm error notsup Required: {"node":">=20"}
          npm error notsup Actual:   {"npm":"10.8.1","node":"v18.17.1"}
          npm error A complete log of this run can be found in: /root/.npm/_logs/2024-07-02T15_30_26_428Z-debug-0.log
          pi@MagicMirror:~/MagicMirror $ node -v
          v22.4.0
          pi@MagicMirror:~/MagicMirror $ npm -v
          10.8.1
            sdetweil @el97
            @el97 I guess the test failed, in package.json says >=20
            I’d install v 20.9.0
            sudo npm install n -g
            sudo n 20.9.0
            el97E 1 Reply Last reply Reply Quote 0
            • el97E Offline
              el97 @sdetweil
              @sdetweil I managed to solve it by installing node with these commands below. I tried using nvm earlier with no luck.
              curl -fsSL https://deb.nodesource.com/setup_20.x | sudo bash -
              sudo apt install -y nodejs
              1 Reply Last reply Reply Quote -1
