    NPM problem "EBADENGINE" which I fail to solve
    19 Posts 3 Posters 26.8k Views 3 Watching
      sdetweil @Ix
      @Ix said in NPM problem "EBADENGINE" which I fail to solve:
      /usr/local/n/versions/node/18.18.2
      does that directory exist?
      I’ve never had any problem with n, on windows, linux or mac.
      do a
      which node
      so we can see where it is coming from
      I 2 Replies Last reply Reply Quote 0
      • I Offline
        Ix @sdetweil
        @sdetweil said in NPM problem "EBADENGINE" which I fail to solve:
        yes I think:
        mirror@raspberrypi:~/MagicMirror/modules $ cd /usr/local/bin
        mirror@raspberrypi:/usr/local/bin $ ls
        corepack  node  npm  npx
        node is colored green in this ls
          sdetweil @Ix
          @Ix note its NOT usr/local/BIN its usr/local/N
          (uppercase fore emphasis here)
          • I Offline
            Ix @sdetweil
            do a
            which node
            here is the result from “a”:
            mirror@raspberrypi:~/MagicMirror/modules/MMM-PublicTransportHafas $ n -a
              Error: missing -a|--arch value
            yeah, but see the error message I posted above: it seems to get the directory wrong as well. sry for me being a newbie in this case
            I really appreciate you helping me here!
            edit:
            file is there:
            mirror@raspberrypi:/usr/local/n/versions/node $ ls
            18.18.2  22.2.0
              sdetweil @Ix
              @Ix no
              do
              which node
              this will tell the path to the first executable it finds
              on my pi4 with node (from n)
              is says
              which node
              /usr/local/bin/node
              on my x64 box with n 18
              it says
              which node
              /usr/local/bin/node
              I S 2 Replies Last reply Reply Quote 0
              • I Offline
                Ix @sdetweil
                @Ix no
                do
                which node
                ah I over read that.
                here’s the result:
                mirror@raspberrypi:/usr/local/n/versions/node $ which node
                /home/mirror/.nvm/versions/node/v18.18.0/bin/node
                well that’s a completely different path… so what should I do now?
                  @Ix the module author says this is a bug in the lint checker…
                  do this, in the module folder
                  npm i @stylistic/eslint-plugin@1.8.1
                  then npm install
                  • I Offline
                    Ix @sdetweil
                    THANK YOU! This did it, the module is working again, finally!
                    You are the best 🙌
                    /solved
                      sdetweil @Ix
                      @Ix not me… another user
                      • I Ix has marked this topic as solved on
