    NPM problem "EBADENGINE" which I fail to solve
    19 Posts 3 Posters 31.4k Views 3 Watching
    • I Offline
      Ix @sdetweil
      @sdetweil said in NPM problem "EBADENGINE" which I fail to solve:
      I use n, which is a nodejs version of nvm
      sudo mpn install n
      n version
      n list
      I also tried this.
      Here are the results:
      mirror@raspberrypi:~/MagicMirror/modules/MMM-PublicTransportHafas $ n list
      node/22.2.0
      mirror@raspberrypi:~/MagicMirror/modules/MMM-PublicTransportHafas $ n version
        Error: invalid version 'version'
        sdetweil @Ix
        @Ix version is the one you want to use
        n 18
        n 18.18
        need sudo to change, as it write to /usr/local/bin which is protected
        (as as nvm does)
        see
        n --help
        • I Offline
          Ix @sdetweil
          I already tried and changed my used version to v18.18 via nvm (what obviously didn’t work)
          Now I installed “n” and tried again with your method.
          mirror@raspberrypi:~/MagicMirror/modules $ sudo n 18.18
            installing : node-v18.18.2
                 mkdir : /usr/local/n/versions/node/18.18.2
                 fetch : https://nodejs.org/dist/v18.18.2/node-v18.18.2-linux-arm64.tar.xz
               copying : node/18.18.2
          /usr/bin/n: Zeile 746: /usr/local/bin/node: Datei oder Verzeichnis nicht gefunden
             installed :  (with npm 9.8.1)
          There is an error: “Datei oder Verzeichnis nicht gefunden” which translates into “File or directory not found” (Sry for my German OS 😅)
          so there is another issue
            sdetweil @Ix
            @Ix said in NPM problem "EBADENGINE" which I fail to solve:
            does that directory exist?
            I’ve never had any problem with n, on windows, linux or mac.
            do a
            which node
            so we can see where it is coming from
            I 2 Replies Last reply Reply Quote 0
            • I Offline
              Ix @sdetweil
              yes I think:
              mirror@raspberrypi:~/MagicMirror/modules $ cd /usr/local/bin
              mirror@raspberrypi:/usr/local/bin $ ls
              corepack  node  npm  npx
              node is colored green in this ls
                sdetweil @Ix
                @Ix note its NOT usr/local/BIN its usr/local/N
                (uppercase fore emphasis here)
                • I Offline
                  Ix @sdetweil
                  do a
                  which node
                  here is the result from “a”:
                  mirror@raspberrypi:~/MagicMirror/modules/MMM-PublicTransportHafas $ n -a
                    Error: missing -a|--arch value
                  yeah, but see the error message I posted above: it seems to get the directory wrong as well. sry for me being a newbie in this case
                  I really appreciate you helping me here!
                  edit:
                  file is there:
                  mirror@raspberrypi:/usr/local/n/versions/node $ ls
                  18.18.2  22.2.0
                    sdetweil @Ix
                    @Ix no
                    do
                    which node
                    this will tell the path to the first executable it finds
                    on my pi4 with node (from n)
                    is says
                    which node
                    /usr/local/bin/node
                    on my x64 box with n 18
                    it says
                    which node
                    /usr/local/bin/node
                    I S 2 Replies Last reply Reply Quote 0
                    • I Offline
                      Ix @sdetweil
                      @Ix no
                      do
                      which node
                      ah I over read that.
                      here’s the result:
                      mirror@raspberrypi:/usr/local/n/versions/node $ which node
                      /home/mirror/.nvm/versions/node/v18.18.0/bin/node
                      well that’s a completely different path… so what should I do now?
                        @Ix the module author says this is a bug in the lint checker…
                        do this, in the module folder
                        npm i @stylistic/eslint-plugin@1.8.1
                        then npm install
                        • I Offline
                          Ix @sdetweil
                          THANK YOU! This did it, the module is working again, finally!
                          You are the best 🙌
                          /solved
                            sdetweil @Ix
                            @Ix not me… another user
                            • I Ix has marked this topic as solved on
