    NPM problem "EBADENGINE" which I fail to solve
    19 Posts 3 Posters 33.9k Views 3 Watching
    • I
      Ix
      Hello everyone!
      Since I updated Kristjan Esperanto’s fork of the module "PublicTransportHafas to the newest version I can’t get it to run. When I use the command “npm ci” after “git pull” I just get the following error messages:
      Note that I tried and updated the version of node.js to the required version (at least I think I did. It does’t seem to work the way I tried).
      Is anyone here who has some experience troubleshooting such node problems? What am I missing? Please help, and Thank you in advance!
        @Ix the module author says this is a bug in the lint checker…
        do this, in the module folder
        npm i @stylistic/eslint-plugin@1.8.1
        then npm install
        I 1 Reply Last reply
          sdetweil @Ix
          @Ix says require 18.18.0 current 18.17.1
          so I would do
          node -v
          hash -r
          node -v
          • I
            Ix @sdetweil
            Hello @sdetweil and thank you for your fast answer!
            I tried and pasted your commands in my terminal. Sadly, it didn’t work…
            Here’s what it says:
            mirror@raspberrypi:~/MagicMirror/modules/MMM-PublicTransportHafas $ node -v
            hash -r
            node -v
            v18.18.0
            v18.18.0
            mirror@raspberrypi:~/MagicMirror/modules/MMM-PublicTransportHafas $ sudo npm ci
            npm warn EBADENGINE Unsupported engine {
            npm warn EBADENGINE   package: '@stylistic/eslint-plugin@2.1.0',
            npm warn EBADENGINE   required: { node: '^18.18.0 || ^20.9.0 || >=21.1.0' },
            npm warn EBADENGINE   current: { node: 'v18.17.1', npm: '10.7.0' }
            npm warn EBADENGINE }
            npm warn EBADENGINE   package: '@stylistic/eslint-plugin-js@2.1.0',
            npm warn EBADENGINE   package: 'eslint-visitor-keys@4.0.0',
            npm warn EBADENGINE   package: '@stylistic/eslint-plugin-jsx@2.1.0',
            npm warn EBADENGINE   package: '@typescript-eslint/utils@7.9.0',
            npm warn EBADENGINE   required: { node: '^18.18.0 || >=20.0.0' },
            npm warn EBADENGINE   package: '@stylistic/eslint-plugin-ts@2.1.0',
            npm warn EBADENGINE   package: '@typescript-eslint/scope-manager@7.9.0',
            npm warn EBADENGINE   package: '@typescript-eslint/types@7.9.0',
            npm warn EBADENGINE   package: '@typescript-eslint/typescript-estree@7.9.0',
            npm warn EBADENGINE   package: '@typescript-eslint/visitor-keys@7.9.0',
            npm warn EBADENGINE   package: 'espree@10.0.1',
            > mmm-publictransporthafas@2.1.1 prepare
            > [ -f node_modules/.bin/husky ] && husky || echo husky is not installed.
            added 436 packages, and audited 437 packages in 43s
            155 packages are looking for funding
              run `npm fund` for details
            found 0 vulnerabilities
            It’s as if it doesn’t recognize my used version of node…
            M 1 Reply Last reply
              MMRIZE @Ix
              @Ix
              Install recent nodejs.
              I don’t know how you have installed the current version of nodejs. So I cannot give you an exact advice.
              Generally I prefer to manage node version with nvm
              I S 2 Replies Last reply
              • I
                Ix @MMRIZE
                @MMRIZE said in NPM problem "EBADENGINE" which I fail to solve:
                Hey @MMRIZE 👋
                I used the following command:
                curl -o- https://raw.githubusercontent.com/nvm-sh/nvm/v0.39.7/install.sh | bash
                which I found here
                this is “nvm” isn’t it?
                  sdetweil @MMRIZE
                  @MMRIZE 1st line of 1st included message image shows his nvm command
                  says using 18.18.0
                  the npm ci says using 18.17.1
                  try npm i
                  I use n, which is a nodejs version of nvm
                  sudo mpn install n
                  n version
                  n list
                  n --help
                  I 2 Replies Last reply
                  • I
                    Ix @sdetweil
                    @sdetweil said in NPM problem "EBADENGINE" which I fail to solve:
                    try npm I
                    also tried this. same result :-/
                    • I
                      Ix @sdetweil
                      sudo mpn install n
                      n version
                      n list
                      I also tried this.
                      Here are the results:
                      mirror@raspberrypi:~/MagicMirror/modules/MMM-PublicTransportHafas $ n list
                      node/22.2.0
                      mirror@raspberrypi:~/MagicMirror/modules/MMM-PublicTransportHafas $ n version
                        Error: invalid version 'version'
                        sdetweil @Ix
                        @Ix version is the one you want to use
                        n 18
                        n 18.18
                        need sudo to change, as it write to /usr/local/bin which is protected
                        (as as nvm does)
                        see
                        n --help
                        • I
                          Ix @sdetweil
                          I already tried and changed my used version to v18.18 via nvm (what obviously didn’t work)
                          Now I installed “n” and tried again with your method.
                          mirror@raspberrypi:~/MagicMirror/modules $ sudo n 18.18
                            installing : node-v18.18.2
                                 mkdir : /usr/local/n/versions/node/18.18.2
                                 fetch : https://nodejs.org/dist/v18.18.2/node-v18.18.2-linux-arm64.tar.xz
                               copying : node/18.18.2
                          /usr/bin/n: Zeile 746: /usr/local/bin/node: Datei oder Verzeichnis nicht gefunden
                             installed :  (with npm 9.8.1)
                          There is an error: “Datei oder Verzeichnis nicht gefunden” which translates into “File or directory not found” (Sry for my German OS 😅)
                          so there is another issue
                            sdetweil @Ix
                            @Ix said in NPM problem "EBADENGINE" which I fail to solve:
                            does that directory exist?
                            I’ve never had any problem with n, on windows, linux or mac.
                            do a
                            which node
                            so we can see where it is coming from
                            • I
                              Ix @sdetweil
                              yes I think:
                              mirror@raspberrypi:~/MagicMirror/modules $ cd /usr/local/bin
                              mirror@raspberrypi:/usr/local/bin $ ls
                              corepack  node  npm  npx
                              node is colored green in this ls
                                sdetweil @Ix
                                @Ix note its NOT usr/local/BIN its usr/local/N
                                (uppercase fore emphasis here)
                                • I
                                  Ix @sdetweil
                                  do a
                                  which node
                                  here is the result from “a”:
                                  mirror@raspberrypi:~/MagicMirror/modules/MMM-PublicTransportHafas $ n -a
                                    Error: missing -a|--arch value
                                  yeah, but see the error message I posted above: it seems to get the directory wrong as well. sry for me being a newbie in this case
                                  I really appreciate you helping me here!
                                  edit:
                                  file is there:
                                  mirror@raspberrypi:/usr/local/n/versions/node $ ls
                                  18.18.2  22.2.0
                                    sdetweil @Ix
                                    @Ix no
                                    do
                                    which node
                                    this will tell the path to the first executable it finds
                                    on my pi4 with node (from n)
                                    is says
                                    which node
                                    /usr/local/bin/node
                                    on my x64 box with n 18
                                    it says
                                    which node
                                    /usr/local/bin/node
                                    • I
                                      Ix @sdetweil
                                      @Ix no
                                      do
                                      which node
                                      ah I over read that.
                                      here’s the result:
                                      mirror@raspberrypi:/usr/local/n/versions/node $ which node
                                      /home/mirror/.nvm/versions/node/v18.18.0/bin/node
                                      well that’s a completely different path… so what should I do now?
                                        then npm install
                                        • I
                                          Ix @sdetweil
                                          THANK YOU! This did it, the module is working again, finally!
                                          You are the best 🙌
                                          /solved
                                            sdetweil @Ix
                                            @Ix not me… another user
                                            • I Ix has marked this topic as solved on
